Question about Ez Access Inflatable Bath Tub Ez Bathe Portable Bathtub With Accessories
Where do i get parts for ez bath
Need parts
  • Ez Access Master
  • 717 Answers
If you can blow into the tubing and start the motor then you need to replace the air button on the tub.
Rod
US Parts Center
888-521-6183
Posted on Apr 25, 2013
Stuck screw
They make an extraction tool called a grabitz
It's a double ended tool which has sort of drill on one end and an ez-out on the other. Use the drill end first then the other with drill in reverse usually will come right out. And put some grease on the new screw before installation and won't have that problem next time
Oct 31, 2017 | Kohler Plumbing
I am looking to replace my left hand bath panel on my beresford shower bath 1700mm white and can not find one can you help
Bath Panels can be very difficult to locate. If the Mfg of your bathtub does not have them available the best solution is to go to Home Depot or Lowes and look in their bath section for a generic panel you can trim to fit.
You may need to change both panels so they match.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Jan 18, 2014 | American Bath Factory Home
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Oct 16, 2013 | Jacuzzi Home
Hydroair magna series whirlpool pump model #LD7AC airswitch does not work. It appears to be connected properly and not blocked. Any suggestions?
If your Bath Pump will not shut off when you push the Air Button, it sounds as if the Air Switch is not working in your Bath Pump.
Click on the Air Switch name and it will show you the replacement part you need to fix the Bath Pump.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Balboa HydroAir Magna Series Spa Eyeball...
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My new EZ-33 cloggs easily with small amount of waste to flush.
you have to take the whole toilet out. you need to check the opening of the down pipe. most likely the wax ring is blocking the soilds. shunt off the water drain out the toilet, unbolt the floor bolts and left it up. clean out the down pipe and replace a new wax ring.
Jun 04, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Need door handle for EZ 1500
This is one of the oldest model sold by Equator and the factory who manufactured this model have stopped producing any more parts for this model including a few others and there is no other company carrying the parts for these models and hence it is not possible to get these parts any more.
Apr 22, 2009 | Equator EZ 1500 Front Load Washer / Dryer
Ez Access Inflatable Bath Tub Ez Bathe Portable Bathtub With Accessories Logo
Top Ez Access Home Experts
john h
Tom Chichester
Are you an Ez Access Home Expert? Answer questions, earn points and help others
