Question about Sharp 20F640 20" TV
Tv shuts down after 10 min.
Tv shuts down automatically after 10 min
    Top Expert:
  • Sharp Master
  • 74,198 Answers
Look for any loose solder terminals at its main power regulator circuit section. Re-solder all suspected solder terminals, by applying a little more solder to each terminals. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy.
Posted on Apr 22, 2013
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Sharp LC-32LE240M automatically shuts down
It should have come with a one year parts and labor warranty so consider looking into getting it fixed under the warranty--opening set or tampering inside would void the warranty.
Dec 19, 2012 | Televison & Video
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Sharp 20F640 20" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
