Question about Yamaha RX-V870 Receiver
Yamaha RX-V879 receiver - display panel is not lighting
System works fine but the display does not light. I just moved and packed the unit carefully in the original box but on hooking it up in new location the display is not functioning. Is there a simple fix such as a fuse or LED that can be done? Is is there a place to get a wiring diagram? the manual doesn't seem to address this problem. thanks
  • 6,784 Answers
Hi, you will have to order the entire display from Yamaha. this display is only one piece. it si replaceable.
Posted on Mar 12, 2009
  • 412 Answers
First you go for a wire check...
check all the LED's are proper connected to system.
THE FRONT PANEL DISPLAY IS BLANK. HAVE I DONE
Perhaps, the manual mentions a Dimmer setting under the Display Set Menu but doesn't specify how dark it can get. Give it a try.
Dec 26, 2009 | Yamaha RX-V1000 Receiver
Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Nov 09, 2009 | Audio Players & Recorders
Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
Yamaha receiver rx-v661 display light is out
lamps are burnt out or missing power to backlight system.
please check all the fuses.
nuwan.
Jan 13, 2009 | Yamaha Audio Players & Recorders
Yamaha RX-V2095
Hey there! Nice receiver :0)
Sorry about your troubles. I've been where you are with an Rx-V2600. Would turn on and after a few seconds click off. I thought maybe it was bad wiring but even completely disconnected it would still do it.
I took it to a shop and I was told it was a bad channel. Luckily I mentioned I had a Denon receiver that had stopped working and he said he would take that as payment.
He fixed the Yamaha and it's been working for years.
If you search the internet you should find a local authorized Yamaha repair center. I would take it there. They marked charge like a $30-$50 fee to look at it but usually they apply that towards the repair.
Mar 05, 2017 | Yamaha RX-V630 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Sep 26, 2007 | Yamaha RX-V870 Receiver
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
226 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
