Question about Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA - 2500 1/8 Hp
Fuwa 200-ma manual - Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA - 2500 1/8 Hp
I need to know the voltage for behringer power supply adator
The power supply for the FCA202 is rated for 12V DC at 200 mA. (The AC power adapter connects to 120V AC, 60 Hz in the US. The UK version is for 240V, 50Hz.)
The specifications are on page 26 of the User's Manual: http://www.behringer.com/assets/FCA202_P0451_M_EN.pdf .
Jan 20, 2013 | Behringer F-CONTROL AUDIO FCA202 External...
How to connect the canon ma-200 to the canon xl1
You can mount the MA 200 shoulder pad to the XL1 and plug the RCA connector and the mini plug into the port located on the back of camcorder, first open the door. Next, on the side panel where the audio controls are select AUDIO 1. Now assemble a mic using an XLR Cable. Then plug it into the AUDIO 1 port located on the MA 200 Shoulder pad and conduct test. if your using just one mic test the right side, take notice of the gauges located under the handle. the levels should be jumping like crazy. Now remove the XLR cable from the right side and test the left side making your desired audio levels. Now that should work with out question. If not just email me and ill refer you to the YOUTUBE VIDEO. Email me at: dtspmedia@yahoo.com Peace, Enjoy your video sound.
May 27, 2012 | Canon MA-200 Microphone for XL1, XL1S
I would like the wiring instructions for a jvc kd-g845
Wiring harness connections as described in the installation manual:
  1. Black: Ground to metallic body or chassis of car.
  2. Yellow: Terminal in fuse block connecting to car battery (bypassing ignition switch) (constant 12 V).
  3. Red: To an accessory terminal in the fuse block.
  4. Blue: Power antenna if any (250 mA max).
  5. Blue with white stripe: To the remote lead of other equipment (200 mA max).
  6. Orange with white stripe: To car light control switch.
Speaker connections:
Left front: + White - White with black stripe
Right front: + Gray - Gray with black stripe
Left rear: + Green - Green with black stripe
Right rear: + Purple - Purple with black stripe
Jul 17, 2011 | JVC Car Audio & Video
I have a stand up pro air compressor that does not shut off when at pressure
well thats due to the pressure switch broken or faulty buddy replace it these sometimes do play up so buy one off ebay
Nov 15, 2009 | Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA...
Bonjour, je n'arrive pas à associer ma
Il faut utiliser le code RC qui est marque sur l'etiquette au dos du repondeur !
Oct 06, 2009 | Philips Zenia Voice Cordless Phone
How do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
There is usually a regulator where the air coupling is. if not,just add one with some simple fittings and a regulator you can find at home depot in tool dept.
Jul 16, 2009 | Fuwa Fuwa Kutsuwa Fuwa Air Compressor MA...
My 24 volt batteries stopped holding there charge
Is you battery charger producing the correct voltage? I would check that first, because that has happened to me. Other than that, battery replacement may be necessary. It is important to let them properly discharge and charge them as your manual says, as batterys will fail if not properly cared for.
Jul 04, 2009 | Makita BHR200SAE Cordless Rotary Hammer
Fuwa Fuwa Kutsuwa Fuwa Air Compressor  MA - 2500 1/8 Hp Logo
22 people viewed this question
Top Fuwa Fuwa Kutsuwa Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Fuwa Fuwa Kutsuwa Air Tool and Compressor Expert? Answer questions, earn points and help others
