Question about Schwinn 820 P Treadmill Silver Service Delivery
Treadmill will not come out of lockout mode.
I removed the key to show someone how it works and when I replaced it the message continued to read safety key/lockout. I have turned it off and on and unplugged and plugged it back in.
Display is in 'demo mode'?
Before inserting key hold down stop key then insert key then turn off demo mode
Jun 03, 2015 | HEALTHRIDER S500XI TREADMILL Console
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
Just bought from store press reset button it lights up but does not display after or start
Make sure the safety key is inserted this engages the power up sequence for the unit to start operating. Also as a simple test try to get the unit into calibration mode by pressing the stop and speed up buttons at the same time while inserting the safety key Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
If either attempts fail then call the store where you purchased the treadmill, either have them send a service tech out or exchange theunit.
Jun 26, 2010 | Weslo Cadence Ct 5.8 Treadmill
Seems to be stuck in a programcan't change speeds won't incline.have reset numerous times with no luck.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
Jun 11, 2010 | RTO Image 15.0R Treadmill Walking Belt
Treadmill turns on but belt not turn on
Press the Stop and the Speed Up keys down while inserting the safety key this will get the into calibration mode. The next step is to press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. if it says 2F, FF or Fail then the upper console needs to be replaced
If the belt does not move in this mode then the controller board is defective and needs be replace.
Jun 01, 2010 | HEALTHRIDER S300i Treadmill Motor Control...
Manual to trouble shoot/run diognostics
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Will not move belt
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
My treadmill turns on but will not start showing fp
press the Stop key and then remove the safety key this should get you out of the calibration mode.
May 14, 2010 | Proform Crosswalk 500 Treadmill
MY HP 1740 FLAT SCREEN MONITOR IS SHOWING A OSD LOCKOUT WARNING
Might be this...
For an OSD Lockout message, press and hold the Menu button for 10 seconds.
For a Power Button Lockout message, press and hold the Power button for 10 seconds.
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3648453&prodTypeId=382087&objectID=c01508108
But then this post says he had to hold it down for 25-30 seconds...
http://h30434.www3.hp.com/psg/board/message?message.uid=59866
Mar 17, 2009 | HP Computers & Internet
Schwinn 820 P Treadmill  Silver Service Delivery Logo
37 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
