Menu setting for Samsung Sync Master794MG - Computers & Internet
How do I fix Master Sync disabled on my Samsung Galaxy J3 Phone
Fix " Email sync disabled " Through Settings:
  1. Go to Setting of your device.
  2. Now select Accounts from the menu.
  3. Devices running on 4.4 KitKat ( You'll found Accounts in General Tab ).
  4. Now select Google from accounts list.
  5. Make sure you have checked all the Options. ...
  6. Now Tap on " Sync All ".
Nov 11, 2017 | Samsung Cell Phones
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
I am using samsung s duos.Amdroid version 4.0.4.Previously I used to receive gmail notification when the phone was connected with internet but suddenly stopped getting gmail notification.I want to enable...
Try these solutions:
1. Go to settings > accounts > Google > **your email**@gmail.com > Enable Gmail sync
2. Settings > Mobile Data > Gmail > Restrict access disabled
3. Settings > Mobile Data > (menu button) > Enable Sync
4. Settings > Applications > (scroll right to all) > Gmail > Show Notifications enabled
5. Gmail > (menu button) > Settings > **your email**@gmail.com > Enable Notifications and enable Sync gmail.
*Note that I'm using a dutch language on my phone so the terms I used are guessed translations, actual buttons might have a somewhat different text on your phone.
Mar 18, 2014 | Samsung GT-S7562L Galaxy S Duos With Dual...
How do I log out of the facebook app on the Samsung Vitality phone?
Select menu > settings > Accounts & sync > select f/b > auto sync and un check it. Under manage accounts select f/b and remove account. Then select f/b from main page and log in setting up your account again. Keep auto sync unchecked in accounts and sync settings so you have to manually log in each time.
Nov 27, 2011 | Cell Phones
How to copy htc3300i contacts to pc/ samsung monte
1.Download HTC Sync 2.0.40 and install 2.Connect your HTC and PC 3.Tab connection setting in HTC Sync display menu (when you connect to PC Sync menu will automatically display) 4.Tab contacts.All the contacts in your handset copy to PC.
Mar 06, 2011 | HTC P3300 Smartphone
XBox 360 Rockband out of Sync with TV
You must plug the HDMI cable from the Xbox into the port on the side of the tv. Go into the menu and set to game mode.
Oct 04, 2009 | Samsung Televison & Video
PIM SYNC NETWORK ERROR on F480 Touch Screen Phone
Samsung are rubbish for this!
You need to go to Menu - Settings - Memory Settings - Clear Memory.
Select Calendar, Tasks and Memo and press ok.
You should now be able to connect to your pc and the sync will work.
Oct 26, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Feb 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Time Display
Change the time and date manual in the Settings menu and turn off the box that says autmatic update thingummy
Aug 26, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
