Question about IBM System Storage DS3400 (172642X) Hard Drive Array
Ds3400 drive online - IBM System Storage DS3400 (172642X) Hard Drive Array
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Dec 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Removing write-protectiion
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage to the firmware, data can be saved
2. Damage to the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and firmware repair.
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Oct 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i connect transcend jf v30 16 gb pen drive it takes lot of time and computer doesnot respond and it displays as unreadable format or corrpted
There are three possible
3. Bad sector
Oct 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a JF V33 Transcend USB and I tryed JFSW and JFSW2 to try to reformat the USB but, they both cant read the USB I need help ASAP plzzz
There are two possible
I can't erase index marks on my olyjmpus ds3400. The instructions in the manual don't work.
If you cant erase index marks then suggest you reformat unit...instructions are in users guide...be aware this will erase all recordings.
Oct 30, 2010 | Olympus DS3400 Handheld Digital Voice...
We forget the ip address for the MGMT port, we changed the default one
use arp .
find the mac address and then use arp to assign an ip address to the mac address . the you can enter the web front end using the ip address you assigned to the routers mac address and then find out or change your ip address. might not be any use to you
Mar 03, 2010 | IBM System Storage DS3400 Dual Controller...
I click safely remove hardware and pluged my hard drive back in the USB port my computer will not put it back online
reboot the PC with the drive connected and powered on.
Navigate to commputer management/drive management and make sure the drive is online.
Jan 30, 2010 | Maxtor MaXLine Plus II 250 GB Hard Drive
"Running online games from ps2 hard drive" problem
Are there any other games saved to the hard drive that play OK, Is this the first time that you have tried to run games from the hard drive? Is the hard drive set up OK to begin with? What software are you using with the setup to save the games to the hard drive, Has it all been working OK before now?
Sep 19, 2007 | Sony PlayStation 2 (PS2) Console
IBM System Storage DS3400 (172642X) Hard Drive Array Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
