Question about LG Microwave Ovens
MICROWAVE DOESN'T WORK
FRIEND TRIED TO USE TIMER ON MICROWAVE WITH NO FOOD IN IT. tHE GLASS IS BROKEN AND THE MICROWAVE NO LONGER WORKS. DID HE DAMAGE IT BY THIS PROCESS
    Problem Solver:
  • 14 Answers
Can i please ask how long the microwave was running without any food present?
Posted on Mar 12, 2009
Mic.oven takes longer to heat food
The microwave may not be cooking at full power, check the settings. If okay the magnetron is on it's way out and will eventually fail.
Jun 11, 2012 | Emerson MW8168B Microwave Oven
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
Ran the microwave with nothing inside. Now microwave is not working.
When you say it's not working do you mean it is completely dead??? or it turns on but it don't heat??
When running an empty microwave it can damage the MAGNETRON because the inside coating of the microwave is design to bounce (reflect) the waves to whatever is sitting in the bottom/middle (food)... if nothing is there to ABSORB the waves, than it bounces back into the MAGNETRON and can damage it (if it runs long enough)... the magnetron is generally more expensive to replace than the oven it self... so to make sure if the magnetron is working, you could try a test with a HENE lamp (small orange neon bulb) in a glass of water, put the bulb in a full glass of water than put the glass in the oven, start the oven, if you see the bulb glowing orange (lights up) it means that the MAGNETRON is working, if not than you need a new oven...
Mar 20, 2011 | Maytag Microwave Ovens
Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat food, new smart board unavailable?
HAVE YOU THOUGHT ABOUT TRYING TO BUY A USED ONE AND TAKING THE BOARD FROM THAT ONE AND PLACING IT IN YOURS ?
Apr 13, 2009 | Microwave Ovens
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Microwave doesn't work
There is a reset somewhere around the top or close to heating element
Mar 12, 2009 | LG Over-the-Range Microwave
Microwave serial # xr2004675 superba heating
If the door seals tight & properly and the fine screen / mesh in between the door glass panels is not damaged, there should be no leakage.
But the risk remains that moisture and food particles will get into cracks and crevices and lead to arcing or rust, both of which can eventually damage the mesh.
What is the small curved piece that's falling out? Can you post a photo of it?
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | Microwave Ovens
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
