Question about Kenwood KDC-255U - CD Receiver
My kenwood KDC-255u works but when i plug in usb it reads but no sound
WHEN I PLUG IN MY iPHONE4 via usb the unit starts to read and plays with no sound or it will flash reading and shut off and keep doing this> i have reset both phone and hu. this problem occured when i was messing with my settings and found the firmware update section, pressed yes and didnt know what was happening so i just shut it off. next thing i know, problems
  • 5 Answers
SOURCE: ipode
The problem is that Apple rewired the USB port on both the ITOUCH and the IPHONE. hey've made it an Apple only connection now . Run out of your headphones to the AUX in on radio
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
reynosaelect
  • 165 Answers
SOURCE: the cd changer can't be read.
Find the RESET button, in sometimes is on the display,or in sometimes is on the cd changer,good luck.
Posted on Mar 23, 2009
SOURCE: USB folder names-Kenwood KDC-X591
Push the AME button in the upper right hand corner of the unit and at the same time hold the fast forward button on the face of the unit - do this for 5 secs. The word "Code" should pop up (not blinking).
Using your remote control press the following numbers:
5 (two times for letter "K")
2 (three times for letter "C")
2 (one time for letter "A")
7 ((two times for letter "R")
Then using your remote control, press the fast forward button and you are done. "Approved" should pop up on the unit.
Hope this helps!
Posted on May 09, 2009
SOURCE: my kenwood kdcx492 usb and cd player wont read
I have the same problem.
Posted on Jan 03, 2010
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Cheers,
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
Playing ipod on kenwood
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Mar 06, 2010 | Kenwood KDC-MP235 CD Player
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
I own a kenwood kdc-x991 and a 2nd gen I-pod put the two togather, worked good for about ten min, then I-pod shut down and kenwood unit is sending an USB error reading.Does anyone have an idea how to slove...
Yup...if you use an alternative power source for the usb device....it appears to work fine now. I have (bought from fry's electronics) an adapter now that plugs into my cig lighter and haven't had any trouble anymore.
Dec 26, 2008 | Kenwood KDC-X991 CD Player
CLAUDE
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
Usb kdc-x890 IPOD
The 890 doesn't support iPod control via USB. You can only read plain data storage devices on the USB port, such as a flash drive or portable hard drive. When you plug the iPod in (to a PC or the 890), it doesn't show up as a plain file storage device. Some of the newer Kenwoods do offer direct iPod control via USB. These ones have more "smarts" and are able to properly talk to the iPod and access its music. For the older models, you'll need to buy the special iPod interface, which accesses the iPod like a CD changer.
Mar 20, 2008 | Kenwood KDC-X890 CD Player
Ipode
Mar 08, 2008 | Kenwood KDC-MP435U CD Player
Kenwood kdc w5534u
Hi! I have problem with usb...i try to connect 5 or 6 diferent usb flash device and after reading it shown that no device? it is a technical problem? Thanks!
Jan 06, 2008 | Kenwood KDC-W5534U CD Player
Kenwood KDC-255U - CD Receiver Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
