Question about Microsoft Windows XP Professional
Windows XP operating system is failing when skype connects
It has now become impossible to boot up the machine at all due to XP system failure. A brief connection this morning crashed again as soon as Skype connected.
  • jpaul1216 May 11, 2010
    what is the system failure message? does it give an error code?
  • 8 Answers
Restore your computer
Posted on Mar 18, 2009
My laptop operating system failed to start it has an error code: 0xc0000001
It is probably a hard drive failure and will either require the operating system to be repaired, rebuild or at worst case the hard drive to be replaced and then the operating system to be reinstalled.
It is impossible to go further without expert examination so I advise you to find a reputable repair man.
Aug 21, 2014 | HP Computers & Internet
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
I have an operating system Windows 2000 and when I installed e new version of Skype (5.3) the program refuses to start and show next message: Failed to get proc address for SetIdDirectoryW (kernell32.dll)....
System requirements for Skype 5.3
  • PC running Windows® XP, Vista or 7, both 32- and 64-bit operating systems.
  • Internet connection - broadband is best (GPRS is not supported for voice calls).
  • Speakers and microphone - built-in or separate.
  • For voice calls recommend broadband connection with 100 kbps down / 100 kbps up.
  • For group video calling everyone on the call needs Skype 5.0 for Windows or Mac or higher plus webcams, and at least one person needs a group video calling subscription. For best quality we recommend you use a high-speed broadband connection of 4Mbps down / 512kbps up and a computer with a Core 2 Duo 1.8 GHz processor. As a minimum you'll need a high-speed broad connection of 512kbps down / 128kbps up and a computer with a 1 GHz processor.
Note :Please consider in Processor, RAM, VGA and harddisk. those the main thing to decide whatever Skype 5.3 for Windows can be installed properly in computer system or not. If one of those minimum requirements can't be achieved by your hardware, please don't even try to install Skype 5.3for Windows.. Leave comment if you have something to ask!!
May 04, 2011 | Computers & Internet
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
WINDOWS XP & VISTA drivers
Yes you can dual boot any computer with vista and winxp.
Also you can user your web cam with winxp and vista.
Jul 31, 2009 | Computers & Internet
Cannot reboot xp operating system due to power cut...
well ur window has been corrupted due to power failure.try to repair it or install it again.
Jun 26, 2009 | E-Machines (T2958) PC Desktop
SKYPE CONNECTION TO VTECH 7100 PHONE
go to www.vtechcanada.com click on cordless phones then click customer support and click on software down load and look for "For Windows Vista operating system:
USB7100 Setup version 2.35 – For use with Skype." save it and after that reboot your cpu and open your skype , log in and then open vtech cordless phone suit and check if all of the options there has a green check mark .. ok :-) and it will work and make sure you are using the 3.0 or 3.8 for your skype because 4.0 would not work. you can down load it in google skype version 3.8 or 3.0 ..
Aug 08, 2008 | Vtech USB7100 IP Wireless Phone
Microsoft Window XP
Your problem is in the virtual basic script. That is the language that Windows has supported since Win 98 came out. It is most helpful on internet explorer. Somehow your boot file has been corrupted. There is a way to edit this in your registry through Regedit, but you need to be very familiar with the Registry before attempting that alone. I recommend finding a virus protection software package to help you debug your computer.
CH
Jul 30, 2008 | Microsoft Windows XP Professional
Windows Vista & Window XP operating system
u can dual boot them u need 2 creat another paertision enough 4 the other os
Jul 04, 2008 | Janome Memory Craft 9000 Computerized...
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
http://www.dll-files.com/dllindex/dll-files.shtml?hal
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
100 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
