Question about Kenmore 74992 Gas Dryer
The dryer still operates just not using hot air. my gas service is still on in the rest of the house. it is a kennmore front loader
  • 221 Answers
It sounds like the thermal fuse is bad.
Posted on Mar 12, 2009
I have an amana 90 10 years old the blower starts and the igniter glows but the gas does not come out and ignite. the furnace tries three times to start but quits after three tries. What can I do
Hello,1st check that the gas valve is on (the knob on top).2nd check that the gas handle is open in the gas pipe next to the unit.3rd was any work performed on the gas service (new gas stove,clothes dryer,hot waterheater,fireplace) there might be air in the gas pipe that has to be purged out.It is safe to reset the unit and let it attempt to light 3 trys.(turn the power switch on/off) untill the air is out.Listen for a "click" from the gas valve thats is when the gas is on.It is a fuel supply problem,is the gas to the house turned on?any street digging in front of the house by others?Your utility company can check.
Oct 27, 2010 | Amana Heating & Cooling
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
May 20, 2010 | Dryers
Dryer Runs But wont dry
The first place to check should be the hot surface igniter. You should be able to inspect the hot surface igniter with a flashlight after you have removed the bottom front panel. If there are any white spots or complete break-offs in the igniter than it should be replaced.
If the igniter seems to be functional then it may be the thermostat that needs to be replaced.
Mar 22, 2010 | Maytag Neptune MDG9700A Gas Dryer
Kennmore dryer wont heat
Your problem could be one of the following:
* thermostat
* gas coils
* radiant sensor
* gas igniter
* timer
Contact an appliance service company.
Feb 20, 2010 | Kenmore 93142 Gas Dryer
Dryer functioning but air not getting hot. this is a Maytag gas dryer
Things that could stop a gas dryer from heating:
Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up (no continuity) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryer’s air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, cannot be re-set, must be replaced if is open (no continuity between pins).
Thank you for contacting Fixya.com
Aug 18, 2009 | Maytag Dryers
My front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Jun 22, 2009 | Maytag MDE9206 Dryer
My kennmore gas dryer will not heat it spins and i turn the timer on and off and that works there is gas to the unit
unplug dryer , remove back panel and you will see a thermo link in about the middle of the back of dryer with a vom test continuity of the link this is a very common problem . if no continuity replace thermo kink . if it tests good remove access pane in front of dryer and turn the dryer on to a heat cycle, see if the ignitor coil gets red hot. if it doesn't then the ceramic coil is bad. these are the 2 most common problems with gas dryers. if still no good write back
Jan 26, 2009 | Dryers
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Whrilpool gas dryer
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Jan 15, 2008 | Whirlpool GGQ8831L Gas Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore 74992 Gas Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
