Question about Toymax Magnavox 37MF231D 37 in. LCD TV
Need to replace 1200uf 35v capacitor for magnavox 37mf231 tv
Not sure if capacitor is low impedance aluminum elecrolytic, thats the question I get when looking for replacement.
Thanks for any help,
Doug
2 Suggested Answers
  • 13 Answers
SOURCE: magnavox 37MF321D/37 power light & screen flash, won't come on.
The capacitors in question are as follows. 2074 is a 2200uf 35v 105degree celsius. 2081 is a 1200uf 35v 105 degree celsius. I would recommend the smallest solder you can find, and use a 35 w solder pencil.
Posted on Sep 30, 2009
  • 8457 Answers
SOURCE: I need a 1200uf 35v radial capacitor
Try website Ebay.com to buy these capacitors.
Posted on Mar 26, 2010
LCD TV won't turn on- power light flashing
This is a very common symptom of a failure in the power supply board. The failure is caused by parts called capacitors. Here is a link to information on what needs to be replace on the power supply board to repair it. It is an easy repair, takes about 20 minutes.
http://www.ccl-la.com/catalog/product_info.php?cPath=95_97&products_id=216
Jul 21, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Can i use a 1000uf 35v for replacement with a 1200 uf 35 v? for a magnavox 37MF331D 37 in. LCD TV
Absolutely NO! Although it may be close, you will find a poor startup just as if the set was still bad. The capacitor you need is of course a 25 volt 1200MF. In this case a 35 volt 1200MF will work. I would suggest in this case a next up voltage with the correct MF. In this case the best sub is the 35 volt 1200MF. Check out Matelectronics.com. or MCM Electronics.com or Mouser Electronics .com. If you have a local Electronic supply store they may have what you need. I do not believe you will find it at Radio Shack. Thanks for asking and show a few hands of support!
Nov 13, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
The tv will only turn on if power is removed (plug pulled). Works fine until turned off then AC power must be removed before coming on again.
Other sites show that power up problems are due to the aluminum electrolytic capacitors on the power supply board being defective. Replacing the four 470uf 25v capacitors (470 micro farad, 25 volt) on the board usually fixes the problem. Sometimes also the two 1200uf 25v capacitors could be the culprit. I suggest changing them all. The price is about $7 for the parts online at Mouser electronics plus $7 shipping. I just fixed mine. I bought two 1200uf 35v capacitors, Mouser part number: 647-UPJ1V122MHD6 and four 470uf 25v capacitors Mouser part number: 661-EKY250ELL471MH2 These are slightly larger than the originals but still fit and they were in stock. You will then have to open the unit (relatively easy) remove the power supply board by removing four screws and disconnecting the connectors (Make a note of wire colors and where the connectors came from before removing). Then you will need to remove the old parts by desoldering them and then solder in the new parts (somewhat easy if you have soldered before)
Nov 30, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
My Sceptre X32B sill not power on
Nov 28, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Magnavox 37MF321D/37 power light & screen flash, won't come on.
A full capacitor kit for the 37MF337 and 37MF321 models is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=21_77&products_id=216
The kit contains all 8 capacitors needed to rebuild the power supply board
Aug 27, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox lcd tv not turning on
Also changed swollen C2074 and C2081 and it now works perfectly! a bit daunting for a novice like myself but with a steady hand and decent 'put it back the way you took it apart' skills, all went well!
Mar 22, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
Magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Jul 18, 2008 | Televison & Video
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
1,509 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Dave Naylor
Dave Naylor
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
