Question about Intermatic Grasslin KM2ST-2D Timer, 2 Gang 24 Hour Timer with Decora Switch
Grasslun 24 hour timer - Intermatic Grasslin KM2ST-2D Timer, 2 Gang 24 Hour Timer with Decora Switch
2 Suggested Answers
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
Need to know how to set timer #15075
GE 15075 is heavy-duty plug-in-type 24-hour analog timer with pins located around dial.
Each pin represents 1/2 hour. Two consecutive pins represent 1 hour.
Open following links to identify timer and to read detailed instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Aug 31, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
What is a minimum timer setup
Question is not clear, timer is not identified.
Add a comment with in-focus photo of timer posted on flickr.
Minimum on-off time for digital timers is usually 1 minute.
Minimum on-off time for plug-in-type 24-hour analog timers is 1/4 hour or 1/2 hour depending on width of tripper-pin-segment.
Minimum on-off time for plug-in-type 7-day analog timer is usually 3 hours.
Plug-in vacation timers are set for random on-off and cannot be set.
Minimum on-off time for box timers with 24 hour dial and wide tripper is 1 to 1-1/2 hours
Minimum on-off time for box timers with 24 hour dial and narrow tripper is 1/4 hour.
Minimum on-off time for box timers with 7-day dial is usually 3 hours
Open following link for information how to set analog timers
Jun 12, 2011 | Intermatic 10 Amp Mechanical Indoor Timer
Need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
How do i program the 24 hour timer by woods?
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
Nov 17, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Intermatic Grasslin KM2ST-2D Timer, 2 Gang 24 Hour Timer with Decora Switch Logo
21 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
