Question about Tools & Hardware - Others
Trying to locate spare belts for my black@decker sr500e sander
Is a owners manual available
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 302 Answers
SOURCE: Black & Decker 3X21
I have one of those and I just smack the front roller ahead with a brass or plastic hammer. I hit the movable bracket that the roller is attached to. It takes a pretty stout whack to do it though. hope this helps you
Posted on Jan 14, 2010
Testimonial: "Thanks for the help, I wasn't sure if there was some magic button I was missing. Tks, jw "
  • 8 Answers
SOURCE: Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Posted on Mar 11, 2010
  • 40 Answers
SOURCE: I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
Posted on Aug 19, 2010
SOURCE: how do you change paper
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Posted on Dec 04, 2010
Tip
Black and Decker Mouse
If you need an owners manual or list of accessories for the Black and Decker Mouse you can go to Dewaltservicenet.com and download. The only parts that I see available depending on your type number is the pad, cord and switch. I dont see where they made available the brushes or other wear and tear parts. They do offer a 2 year limited homeowners warranty though. At this site you can also find local dealers
on Jul 22, 2010 | Black & Decker Mouse Sander/Polisher
Black & Decker Belt Sander suddenly stopped working.
Probably not.
It may have just had a part break inside, like the on-off switch, or one of the wires to one of the brushes, etc., etc.
I buy these regularly, and they are inexpensive, which also means they are made of inexpensive ( cheap) parts.
It wouldn't hurt to take it apart, knowing it may not be repairable. Sometimes parts are available on-line.
Be blessed.
Mar 10, 2013 | Black & Decker BR318 3" x 18" Belt Sander
I have a Black and Decker Sander, model # 5.2 A and I cannot find a motor belt for it. The belt that broke has "made in China" stamped on it and the numbers 110XL 031 stamped on it.
You might try Dewalt. I have a Black & Decker weed eater that had a broken belt and I had to order it from Dewalt. I was told that they had some kind of merger. Ordered it and it worked just fine.
Mar 01, 2011 | Black & Decker BR300 3''x18'' Belt Sander
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Jan 07, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Tools & Hardware - Others Logo
63 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
