Question about Sewing Machines
Nneed a manual for a pfaff redwing model 11 - Sewing Machines
I have a pfaff expression 4.0 and can’t find how to change the tension
This machine has an electronic thread tension control. You'll only be able to adjust the tension for the current stitch, until you turn off the machine or change your stitch selection. Press the Setting button and use the Up/Down arrows on the wheel to get the move the setting selection box on the Thread tension line, if needed. Use the Left/Right arrows on the wheel to increase or decrease the tension. Press OK (the center of the wheel) to save this tension. Test the tension on a scrap of your project and repeat the steps until the thread tension is appropriate for the project. Press Info when in the sewing mode to see the current thread tension.
The manual for the Pfaff Quilt Expression 4.0 (and a couple of other models in the Expression line) is available from Pfaff here: http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/expression_2_3_4-manual-EN.pdf?ext=.pdf . See page 2:16 (page 28 of the PDF) for the details. Pages 2:10-2:11 show the buttons for the Expression 4.0.
I hope this helps.
Jan 28, 2018 | PfaFF Sewing Machines
How to remove thread that has wound itself around the back of the bobbin case on a Pfaff tipmatic 1035. Is it possible to remove the top plate to get access?
Remove the bobbin case. If the machine has a free-arm cover, it should be removed also. On most older machines, there are multiple needle plates (zig-zag or straight-stitch) available so they are removable & exchangeable, but for your machine, you'd have to verify. You'll have to carefully remove the threads by cutting with a tiny pair of scissors and pulling the threads using needle-nose pliers or tweezers. If you are unable to remove all the threads, you may need to take it for service.
PFAFF Tipmatic 1014 Instruction Book Page 11
PFAFF Tipmatic 1035 Manuals
Pfaff Tipmatic 1035 Owner Manual Page 2
Dec 20, 2016 | Sewing Machines
How to thread a pfaff 2042 machine
You might try contacting Pfaff Support:
Machine Support
May not be your model, but frequently machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading.
Threading Pfaff Sewing Machine Select mov
Manual:
Pfaff quilt style 2042 manual
FAQ Knowledge Base
Dec 17, 2016 | PfaFF Sewing Machines
Where can I get service manual that will show me the exact procedure from start to finish a adjusting a 145 pfaff sewing machine? I do not need parts manual or service manual to thread the machine?
go google and type in --workshop manual for PFAFF sewing machine model 145
there is a site that is pdf version down load but before you down load it open the version up to see if it is a workshop manual or repair manual and nor service or operators manual
Nov 14, 2015 | PfaFF Sewing Machines
Where to download free service manual for Pfaff 2020
Free Pfaff PDF Manuals - Sewing Discussion at Stitcher's Guild ...
artisanssquare.com > ... > Sewing Machines
Feb 9, 2011 - 35 posts - ‎19 authors Hello,here is a list of free pdf manuals for many older Pfaff sewing machine and serger models in several languages from the VSM Group.
Sep 26, 2015 | PfaFF Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
Looking for books or manuals for the Pfaff 7570
happy sewing
http://www.cyberport.net/users/milnerwm/FAQ.html
Apr 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
48 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
