Question about Ashly FTX-2001 Amplifier
Ashly ftx 2001 schematics - Ashly FTX-2001 Amplifier
Remote starter auto locking doors
it may be programmed into the remote as a safety feature.. ask the dealer..
Jan 21, 2014 | Cars & Trucks
My power chair got wet in rain and won't start and lights olny flashing and what is meaning of vsi? how to ftx problem..please help!
VSI is the controller under the joy stick. Water will ruin the electronic circuits . The controller is expensive new. You can find rebuilt ones cheaper or can have yours rebuilt. Check your local mobility service shop or on line repair facilities.
Oct 12, 2012 | Pride Go Chair Travel Power Chair
I have 1set power amp " ashly ftx-2001" . my problem is one of component spoill ( ic ), i want to change the componet, but i can't see the code, the ic position near from white fuse, the ic have...
If the IC doesn't work take it out then you will be able to read it just fine!
All you need is a soldering iron and a desolder tool. I like the solder suckers best for these jobs.
May 01, 2011 | Ashly FTX-2001 Amplifier
Looking for instruction manual for mr coffee model ftx 49
Cheerfulhear,
Here is an instruction manual for the 12 cup progamable coffee maker the ftx series, the numbers are for the color so this manual should work just fine here is the link: http://www.mrcoffee.com/Manuals/MANUALS/FTX47_43_1450953.PDF
Thank you for choosing FixYa.com
Justin
Apr 02, 2011 | Mr. Coffee FTX49 12-Cup Coffee Maker
Ftx-2001 Ashley amplifier with XR-1two way crossover. I am trying to connect from my EQ (2-1/4 jacks) into my amplifier, do I connect mt left & right out of my EQ into the balanced input XLR. Not an...
The XR-1 is a 2 way crossover. Depending on the resistor networks, it can be anywhere from 50hz to 5khz. If the packs are marked 153, It's 750HZ, if they're 103 it's 1.2khz if 104 it's around 120hz and 154, 80 hz.
The hi side amp is ch1 the low side is ch2 The amp can be configured as a subwoofer bridged amp , a subwoofer with full range dual ch. You can't make it into a stereo amp with out the obsolete stereo input pack that replaces the XR-1 crossover
Dec 28, 2010 | Ashly FTX-2001 Amplifier
Replace light bulb under dash that shines on console and ash tray
remove the ash tray,then remove the screws that hold
the ash tray bracket in place the bulb will be very easy to change then.
Jan 07, 2010 | 2001 Dodge Dakota
Coins are lodged behind the ashtray of my 2001 Acura TL and the ashtray will not close completely. How do you remove the ashtray to get the coins removed?
There should be a tiny tab at the back of the ashtray that you'll need to pry away from the dash and the ashtray should pop out
Aug 13, 2009 | 2005 Acura TL
73 people viewed this question
Top Ashly Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ashly Audio Player and Recorder Expert? Answer questions, earn points and help others
