Question about Samsung Galaxy Tab Tablet PC
My Samsung Tablet 10's screen won't rotate any more.
Please tell me if is is possible to rotate screen on Samsung CE0168 Galaxy tablet. Thanks
it is possible if screen rotation is turned on in settings > display or from the notification shade
Dec 26, 2016 | Samsung Tablets & eReaders
My screen on my tablet won't rotate and it's turned on in settings and notifications
Try going to Settings - Display and making sure you have Auto rotate enabled.... also settings - Accessibility might have the option as well, then turn tablet off completely for 1 minute then power on!
Oct 26, 2014 | Samsung 16GB Galaxy Tab Pro 8.4" Tablet...
How do i rotate screen on my tablet?
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
Aug 13, 2014 | Tablets & eReaders
How do you stop the screen from flipping?
in settings there is a section that you can turn auto rotate off you need to do this if you want it to stop rotating , you might be able to access the setting from dragging the menu bar from top of screen down like on a samsung
Aug 01, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Screen will not rotate
Some tablets will have a physical rotate lock switch. There is also a setting that locks the rotation. Settings > Display. Auto Screen Rotate.
Dec 08, 2013 | Samsung Galaxy Tab Tablet PC
The Galaxy Tab could not rotate, How could i fix it?
slide the drop down menu from the top of the screen (where the time and battery icons are) and click the 'Auto rotation'. that should do the trick. Cheers.
Jan 16, 2011 | Samsung Galaxy Tab Tablet PC
Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Dec 22, 2007 | Samsung Q1 Tablet PC
Samsung Galaxy Tab Tablet PC Logo
32 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
