Question about Toro Power Lawn Mower
How to install toro lawnmower model 20480 primer bulb
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
  • 5 Answers
SOURCE: I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
Posted on Aug 05, 2009
SOURCE: I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Posted on May 03, 2010
SOURCE: toro model number 200065 won't start. New gas,
some toro primer bulbs don't fill up with fuel but blow air into a chamber in the carb that has fuel in it so when you press the bulb, the air sprays fuel into the carb ( just a little) So since it won't start, the bulb probably has a very small crack in it. replace it and then try it.
Posted on Jan 18, 2011
hunter19_46m
  • 7482 Answers
SOURCE: sparkplug and gap for a toro lawnmower GTS2 model
Hi juaichel5...
Set your plug gap between .28 - .32 with a round feeler gauge to be accurate.
Please take time to rate me
Posted on Aug 16, 2011
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
How to replace carb. Primer?
If you don't see two screws diagonal of each other than there is a little ring holding in your primer bulb. Be careful when removing ring as to not bend out of shape usually new primer bulbs don't come with them. If there are the two screws diagonally, than just unscrew and lift holding plate remove old primer and reverse for install... Good Luck....
Jun 20, 2014 | Toro Lawn Mower With Toro Power Tools
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
Toro model number 200065 won't start. New gas, new spark plug, cleaned air filter. Doesn't feel like fuel is in the primer bulb when I prime it.
Aug 10, 2010 | Toro Lawn Mower With Toro Power Tools
How to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Toro Lawn Mower With Toro Power Tools
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
