Question about Briggs & Stratton Garden
Victa lawnkeeper is blowing smoke
When I start my lawn mower it blows smoke then stops running. I'm not sure if it is an oil issue or not
  • 109 Answers
SOURCE: lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Posted on Apr 21, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
miket756
  • 2702 Answers
SOURCE: my craftsman lawn mower is blowing smoke out the
have a look at the air filter it may be blocked with dead grass causing it to run very ritch and burning up far more fule than you need to, it could also be the choke stuck on, maybe the cutter blade is blunt making it work very hard ,if it is then file it till its sharp again,or the worst thing it could be is the piston rings have worn out and its burning engine oil in witch case fit new rings in it,,,still winter is nearly here and grass dont grow much then do it?
ps, i have a sheep for sale? baaa!
Posted on Oct 24, 2009
  • 152 Answers
SOURCE: Mower blows white smoke
Depending on how old is your mower, it could be broken rings in the engine, or just excess oil. I would recommend to check oil level first.
Hope this helps!
Posted on May 25, 2010
rycgl
  • 1545 Answers
SOURCE: Change engine oil
Check underneath the mower at the bottom of the engine's crankcase and see if there is a possible plug of any type there. Be sure you lift the mower the correct way when tipping , typically with the control handles going down towards ground...not on its side.
Posted on Jun 13, 2010
Testimonial: "The lawnkeeper model doesnt seemed to have a drainage plug at the model as one would expect. I was advised by the manufacturer to tilt the mower to one side to drain the old oil!"
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
White smoke billowing from front of mower
is the smoke from the exhaust?or just the front of the engine look for a oil leak from the head gasket
Apr 30, 2012 | Garden
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
Change engine oil
Jun 08, 2010 | Briggs & Stratton Garden
Hope this helps!
May 24, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Aug 09, 2009 | Garden
I have an early 90's cub cadet rider and it was over filled with oil. Now it smokes and blows oil out the exhaust. Could over filling it cause this? If not are there any common causes of blowing oil
Yes, over filling can cause this. The fix for this is to put the oil level back to normal, and run your machine normally, until the oil residue burns back off. Some "side effects" may be fouling spark plugs and occasionally residue build up in the muffler, so, keep this in mind. Normally, though, everything goes back to normal. It's better to run the machine for a while than starting and stopping it, to allow the machine to get up to operating temperature and clean out the exhaust system.
Best regards, --W/D-- please feel free to rate this solution.
Jul 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Jul 22, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
109 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
