Question about Dell Computers & Internet
What does it mean when the power button blinks rapidly on my Dell E178FPb monitor?
The monitor will not turn on, and the power button light blinks rapidly but will do nothing else. I cannot turn the monitor off or on and it gives no response to moving the mouse.
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
SOURCE: Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Posted on Dec 23, 2008
romsky79
  • 822 Answers
SOURCE: Dell 1704 FPt lcd monitor power button blinking green, no screen.
the only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Posted on Aug 15, 2009
  • 555 Answers
SOURCE: flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Posted on Oct 05, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Tip
Dell Monitor Repair
How to fix a Dell Monitor that just flashes the power light or also flashes the screen on and off very fast. In this video I repair my E178FPb with this problem. In my video, I show how to take it apart, recognize the problem, and replace the parts. I ordered the parts off Mouser and it only cost around $6 with shipping. The problem was visual and I found 2 electrolytic capacitors bulging and a ceramic capacitor burnt. Mouser Electronics Electronic Components Distributor
on Jun 10, 2015 | Dell E178FP 17 inch LCD Monitor
Flashing power light on Dell 17" LCD Monitor. How much cost to get this fixed? Would I come out better getting a new monitor?
I had the same problem and it only cost me $6 in parts and shipping from Mouser and you'll need a soldering iron. I made a video on how I fixed this problem on my Dell E178FPb. Mouser Electronics Electronic Components Distributor
Aug 28, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
What does theblue light mean when its blinking
the steady, blinking blue light means it is working. If the light blinks quickly, ususally 3 times, then it is either turning itself off or turning itself on. if you're getting a steady blink, try holding the button down long enough for it to flash rapidly 3 times in succession. after that, it should blink no more, because you have just turned it off. Want to turn it back on? hold the same button down until it flashes rapidly 3 times again, and you have just turned it back on.
Jan 23, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Please tell me how to remove dell lcd monitor cover
I made a video repairing my Dell E178FPb and I show how to take it apart.
Jun 14, 2010 | Dell E173FP 17" LCD Monitor
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Blinking power light
check your power supply. A flashing amber power button usually means its gone bad
Jul 15, 2008 | Computers & Internet
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
Alun Cox
