Question about Creative Wp-250 Wireless Bluetooth Active Headphone With Remote Control And Mic - Black
Wp-250 will not charge
It will not turn on either - no blue light
Tablet wont turn on
Blue means that your system is not charging, when it is charging it should be pink/purple. when the battery is full it will turn blue. If the blue/pink light stay on it may mean that your battery is no longer charging completely. If it is still under warranty, get a replacement battery for free... otherwise it may be time to invest in a new battery.
Jan 16, 2014 | Computers & Internet
My dreamgear chargepack works but when I but my sliver remote control in it lights up which means that its charging but when I try to charge my blue control the lights wont turn on. how do I make the light...
I have several controlers in several different colors, but "coincidently" several of the blue colored controls have had the LED lights stop working completely. I am begining to think that many blue colored Sixaxis PS3 controlers were made during a version that had problems with the LED lights going out and no longer working, or simply a bad batch of controlers.
Did you try letting it charge for a while, even if the ligfhts won't light up, then press and hold the PS3 button to check and see if it took the charge?
On my blue controlers, they still charge and still work, but none of the LED lights illuminate anymore.
Solution would be to buy a new controler, or ignore the lights not working.
Sep 20, 2013 | Video Game Consoles & Games
My WP-350 is stuck and wont turn on/off
I'm having the same problem with my Creative WP-350 Wireless headphone; the blue light stays lit. I've tried charging the device fully and pressing the + (volume increase) and the multi function buttons with no success. There has to be someone out here that can provide the solution. I wrote to the Creative tech folks too, awaiting for a reply
Jul 07, 2013 | Creative WP-350 Headset
Hyosung ms3 250 battery fully charged engine turns over wont fire up also new spark plug fitted
has spark? has fuel going to carb? if you smell gas from the muffler or carb then it not burning check for spark pull plug touch away from the hole so you don't ignite the vapors on the engine look for a great blue red spark
Feb 24, 2013 | 2009 Hyosung MS3 250
LAPTOP WILL NOT POWER UP, IT HAS THREE FLASHING BLUE LOCK LIGHTS FLASHING
The only time I've seen this in the past is when its a bad motherboard. This repair runs between $250 - $350. If your laptop is more than 3 or 4 years old, I recommend purchasing a new one instead.
If you want to be sure its the motherboard, call a computer repair shop and ask how much they charge for diagnostics. Most charge $20. Don't take it to a big brand name store like best buy or comp usa.
Best regards,Abdielcomputer repair plantation
Nov 15, 2011 | Dell Latitude E5400 Laptop
Netdrive 250 bulb
The bulb is a blue LED (light emitting diode device). this LED will be soldered onto the circuit board.
These LEDs last a very long time and don't normally burn out. Some other component maybe faulty.
May 14, 2010 | Glyph (240295) 250 GB USB Hard Drive
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
Creative Wp-250 Wireless Bluetooth Active Headphone With Remote Control And Mic - Black Logo
Top Creative Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Creative Radio Communication Expert? Answer questions, earn points and help others
