Question about Electrolux EIED55H Dryer
Eloctrulux Dryer EDE 411M
The drum is NOT moving - there IS power supply but the drum is not moving.
Error code on a Frigidaire affinity dryer EDE, E4A
try going to google and put in the model # and the brand along with the error code.
Feb 24, 2015 | Kenmore Dryers
Cloth not dry
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.you can find about uniforms: https://www.mysocceruniform.com/customsocceruniforms.html
Mar 06, 2014 | Maytag Neptune MLE2000A Front Load Stacked...
What is recommended load size for Bosch Nexxt dryer
The Bosch Company is probably known best for its high-end dishwashers, but the company also produces other home appliances including refrigerators, stoves, washers and dryers. Bosch dryers carry the Energy Star rating. A Bosch dryer has a structured drum that provides more thorough drying and condensation drying for faster cycle completion. If mechanical problems occur with the dryer and troubleshooting efforts fail, performing a reset may return the dryer to normal functioning.
Instructions
1Unplug the Bosch dryer from the power supply and then reconnect to the power supply.
2Replace the local fuse or reset the circuit breaker if a fuse or circuit breaker has tripped.
3Place items to be dried into the dryer and select a program. Close the door firmly.
4Press "Start/Pause."
5Press "Stop/Cancel" if the above steps do not resolve the problem.
6Pull the dryer out from the wall and use a standard screwdriver to remove the central metal plate on the back of the dryer.
7Locate the small red reset button above the heating element and press and hold the button for a few seconds. Release the button.
8Place the back access panel back on the driver and move the dryer back against the wall. Repeat steps 3 and 4. If the problem continues, press "Stop/Cancel," turn off power to the dryer and contact an authorized service technician for assistance.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I need the user manual for a EDE 605 dryer but can't find one on line as I need to find out why the buzzer has stopped
Did you find an owners manual? I need it too. Impossible to find online...Thanks!chip@leopoldco.com
Jul 12, 2011 | Electrolux Dryers
Dryer won`t turn on but is plugged in to power source
  • Check that the dryer is plugged in properly and has power. Check the socket with an appliance that is working, such as a fan. If there is no electricity coming from the socket, check your house's fuse box and flip it to on if it has been tripped to off.
    Check the dryer door switch to make sure it it working properly. A malfunctioning door switch is a common cause of a dryer drum not rotating. To check the door switch, you will most likely have to remove two screws from under the lint trap and pull it up to remove a portion of the dryer. Remove the wires from the door switch with the dryer unplugged. Using an ohmmeter, check to make sure you have continuity between the two wires. If there isn't, you will need to replace the door switch.
  • Thermal Fuse
  • Check the thermal fuse if the drum of your dryer is not turning. The thermal fuse will automatically shut off the dryer if the heat inside is too high, but when it malfunctions, it causes the dryer to stop working completely. Before checking the thermal fuse, check to ensure that the vent of the dryer is not clogged, which could cause the dryer to overheat and keep the drum from moving.To gain access to the thermal fuse on most dryer models, you will need to remove the back panel of your dryer. Look at your dryer's manual to find the location of the thermal fuse and replace it with a new one.
  • Motor and Belt Check the belt of your dryer if the motor is running but the drum does not move. The belt controls the movement of the drum from the power of the motor. The belt will either be located under the drum of the dryer, or in the back depending on the model. Find the location of the belt and, if it is broken, replace it with a new belt.
  • If the dryer drum is rotating then stops after about 30 seconds the motor is probably faulty and needs to be replaced. Before replacing the motor, check the fan blade of the dryer to make sure it is not blocked. This can cause the motor to cut out.
  • Sometimes the wiring connection from your home can burn and sever the connection with the dryer's power cord. If so, you will need to replace the power cord and the terminal block that attaches it to the dryer to give it power. This is one of the more expensive fixes, so check everything else before narrowing the problem down to the wiring.
    Oct 11, 2010 | Whirlpool Dryers
    Frigidaire sensor gas dryer will not turn on, power supply and breakers ok, Makes a noise like it wants to turn on. Drum is free and moveable.
    if you can move the drum by hand and it's humming it sounds like you have a bad motor or the belt broke and is jamming the motor and that's why the drum moves,you have to get in there and check it out,open the door and the model number should be there,next time send model number
    Apr 13, 2010 | Frigidaire FGQ332ES Gas Dryer
    Not drying clothes completely
    Jul 19, 2009 | Estate Dryers
    Thumping while drum is turning
    probably is remove console screws and lift console up turn power off first after lifting console remove the 3 screws along back edge slide top forward and off resore power and try ..top may ahve been bent down during move not much clearence between top and drum
    Jul 18, 2008 | Kenmore 63942 Dryer
    Drum does not move
    dryer...there is no way to lubricate anything...all bearings are sealed. Get in there and look around. Turn off the gas and remove the line of you can't get access... and disconnect the power. Remove the back. Chances are you'll find that the motor, drum or belt is somehow jammed. Make sure any fan is turning freely with the belt off. It is possible that the timer is bad. This would keep the motor from receiving power. To test...remove the motor belt and turn the unit on.
    Dec 16, 2007 | Estate TGDS740JQ Gas Dryer
    Electrolux EIED55H Dryer Logo
    96 people viewed this question
    Top Electrolux Dryers Experts
    John Tripp
    John Tripp
    vince
    JP Services
    JP Services
    Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
