Question about Apple iBook G4 Mac Notebook
IBook g4 stuck on window localhost:/ root#
I have tried to put cd in drive to boot from that but it still wont work. please help
  • 22 Answers
SOURCE: ibook G4 14" 1.4mhz
On an Apple system, this is an indication that it thinks there is little or no battery left and goes to sleep to protect data loss. Your battery might be going bad (showing a full charge, but lasting for only a few minutes) or there may be a problem with your power supply.
Posted on Nov 14, 2007
  • 14 Answers
SOURCE: apple 12" ibook g4/1.33ghz won't turn on
your hard drive has failed
it needs to be replaced(2.5" ide) on ebay they are pretty cheap
anything else i could help you with?
Posted on Aug 10, 2008
seaniepie
  • 250 Answers
SOURCE: ibook g4 12" 800mghz freezes alot, especially when bairly moved
Hi Robert
Try a reset of the PMU, instructions here:
http://support.apple.com/kb/HT1431?viewlocale=en_US
All the best
Sean
PiDigital
Posted on Dec 31, 2008
jgcalifornia
  • 160 Answers
SOURCE: ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Posted on Feb 18, 2009
landsend
  • 1066 Answers
SOURCE: dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
Posted on Mar 13, 2009
My ibook stays on the white screen but the apple and the spinning thing doesnt show up but i hear the chimes and i am trying to download my new os x software please help me get it to work
You may have a bad hard drive. The "chime" means that the iBook was able to power on, and the white screen means that it foung the efi or firmware, but the fact that it will not go to the apple or the spinning gear means that it cannot detect an operating system on a hard disk.
Do you have the OSX CD? Put the CD in your ibook, power it on, and hold down the "C" key. This will allow you to boot to the CD. if the hard drive is still good, then it will allow you to install, if not then it will tell you there are no hard disks available. Hope this helps.
Mar 14, 2011 | Apple iBook G4 Mac Notebook
I have a cd stuck in my laptop computer. It's a iBook G4. The cd tray doesn't come out. there is a mechanism that helps to push the cd out. I dont know the best way to get it out. Please help!! E
Option 1:
If you restart the computer and just after it restarts if you hold down the eject key on the keyboard it should eject the disc, if not I would check to see if there is a tiny hole on the disc drive that you can stick a paper clip in - not sure if the ibook will have it but worth while checking.
Option 2:
1. Restart the computer.
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Dec 30, 2010 | Apple iBook G4 Mac Notebook
What is the command to boot from cd on a g4 laptop on startup c button wont make it boot from cd then drops to a shell where i can type things what do i type in the shell to go to the cd drive the shell...
Try starting the machine from the hard drive normally. Put the CD in the drive. Wait until the machine starts up completely. Then,
1. Click the Apple menu (top, right corner of the screen).
2. Click "System Preferences"
3. Click "Startup Disk"
4. Click the CD icon.
5. Click the Restart button in that window. Your Mac will ask you if you are sure you want to restart. Click Restart. It should boot from your CD
Good luck! Please let us know if this helps you solve the problem.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 20, 2010 | Computers & Internet
Unable to install new operating system on ibook G4
If you hold down the option key on startup you should get 2 choices 1 to boot the hard drive 2 to boot the cd/dvd. Use your right arrow key to select the cd/dvd on the right then hit enter.
Or you should be able to boot the cd directly by holding down c on startup.
Mar 31, 2010 | Apple iBook Mac Notebook
I want to have a windows operating system running in my mac
Boot camp and vmware fusion will not work with a G4
there is a version of parallels that will work i hope this helps!
Jan 21, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Stuck dvd
Where your cd drive is there is a small hole which you can insert a straightened paper clip into and this should eject the dvd. Hope this helps.
Nov 22, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I am having trouble reinstalling OS on an ibook g4 I got it to run trough some of the setup but it errored out. when tried again I am no longer able to boot off of cd drive
If you are not able to boot off the cd rom then please just goto BIOS setup of your system and simply change Boot order ( or priorities) to cd rom. and then you will be able to boot properly. Don't panic it will get installed smoothly then.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 30, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Ibook g4 freez
Freezing is a HD problem. Do you hear clicking sometimes? Sometimes on boot up is there a foler with a questionmark in it? I would get your hard drive looked at, this is the reason disc utility fails. Your hard drive has a hiccup.
Jun 19, 2008 | Apple iBook G4 Mac Notebook
No luck
Probably the dvd drive is damaged (boot the computer with a bootable cd and see if it works, if not, change the drive), or it might have weak connection in it's slot, remove it and reinsert it in the laptop, see if it works.
Jan 16, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Mac Notebook Logo
65 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
