Question about Craftsman Garden
Mower doesn't start
Craftsman with Honda engine model 917388880 : Mower will not start. I can see the spark in the spark plug. So the electrical portion is working. Cleaned out carburettor. But the mower refuses to start.
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 10865 Answers
SOURCE: My Mower won't start.
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
Posted on May 23, 2009
  • 4 Answers
SOURCE: craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Posted on Jun 12, 2009
smjdragonfly
  • 79 Answers
SOURCE: have Bolens series 080 22
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms or gaskets and screens on some, tiny jets and such that are inside the little "bulb" or bowl, that can usually be taken off with a 10mm wrench. They also have little fiber gaskets and a bowl gasket or o-ring that must be in great condition with no trash. Clean off with starter fluid or carburetor cleaner.
Posted on Jun 18, 2009
  • 376 Answers
SOURCE: Hello I have a Craftsman eager 1 Lawn Mower model
The breather hose has nothing to do with it not starting. It starts when you prime the carb and dies when that gas is used up. Being a Tecumseh. it's most likely the bowl nut/jet stopped up. Unscrew the bowl nut and clean it. Look cery carefully at the top of the threads. There is probably a very small hole there also and it will not run if it is not open.
Posted on Jun 20, 2009
Testimonial: "Carb kit was on the money installed it on8/20/09 Started and Runs fine"
Al clean the ignition module with some glass paper and also do the fly wheel. Should spark then
Jul 18, 2013 | Garden
Mower under flood water for 2 days.
Hi Steve.You will need to get under the starter pully and rub the spark generator with some glass paper and WD40. No doubt the generator has gone a bit rusty due to the water.The fly wheel will need cleaning to. Also give it a warm place to stay for a few days to completely dry it out. This should be ok then. John
Jul 02, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Spark plug will not seat. Goes in half way. How do I fix.
You've or someone crossthread the threads. You buy plug taps. Be sure the piston all the way down. You may to take head off.
Mar 14, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
19 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
