Question about Honda Garden
Mower doesn't start
Craftsman with Honda engine model 917388880. Changed sparkplug, cleaned carburettor.
  • 10865 Answers
SOURCE: won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
Posted on May 07, 2009
  • 10865 Answers
SOURCE: My Mower won't start.
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
Posted on May 23, 2009
  • 72 Answers
SOURCE: Craftsman Mower - 625 Briggs
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
Posted on May 17, 2011
hunter19_46m
  • 7482 Answers
SOURCE: i have craftman lawn mower it has honda motor
Hi islamamin200..
You have a problem with the inlet float, there is something holding it from closing totally.
When you cleaned the carburetor did you clean it with a cleaning solution such as lacquer thinner, this is used to cut the "varnish" buildup in the jets and needle valves of the carburetor.
Follow the directions below:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 26, 2011
ftw1952
  • 10319 Answers
SOURCE: My Craftsman Riding Mower, model:
The clicing noise is from a worn starter solenoid. You can test the starter to see if good by touching the battery wire connected to the starter to the batteries positive side. That will make the starter to run
Posted on Jun 05, 2011
What causes a Craftsman 24" Snow Thrower not to start.
If you take the recoil housing off you probably will find a mouse nest by the flywheel and that will cause the engine not to turn. You have to clean all the debree out of there and then it should turn.
Jan 26, 2015 | Craftsman Garden
Mower under flood water for 2 days.
Hi Steve.You will need to get under the starter pully and rub the spark generator with some glass paper and WD40. No doubt the generator has gone a bit rusty due to the water.The fly wheel will need cleaning to. Also give it a warm place to stay for a few days to completely dry it out. This should be ok then. John
Jul 02, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
Jul 30, 2011 | Craftsman Garden
My woods mow'n mach (1850) on an upward grade
There is a few things that I would check and might come to a solution to your issue follow this and will help diagnose your mower. Has this engine been over filled with oil?
Has the lawnmower been turned on its side to clean?
Has it ever been serviced because the carburettor diaphragm and air filter need to be changed on a yearly basis.
Jun 13, 2011 | Briggs & Stratton Garden
I have craftman lawn mower it has honda motor gcv160. i had old fuel in the tank now i try to start my lawn mower but doesn't start. i changed sparkplug but didn't work. then i had to clean the...
Hi islamamin200..
May 26, 2011 | Craftsman Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Bought 1000wat hyundai gen ran for two days and died changed spark plug it started on first pull then died after another day any suggestions
Check if sparkplug is wet or oily when removed,clean and heatup old sparkplug in kitchen flame.put it back again an start engine. Stop engine and remove spark plug,check if colour is light brown.If not or black check if choke is not permanently on ,clean carburettor.
Jun 26, 2010 | Sport & Outdoor - Others
Garden Logo
29 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
