Background noise only on Colombo reruns
Background noise on Colombo reruns. Only on Colombo.
jaranya8
  • 238 Answers
SOURCE: have sound, but humming noise is in background
Your audio codec might not be updated. Try installing audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Posted on Jan 04, 2009
yooperbud
  • 8637 Answers
SOURCE: Background Microphone Noise
The problem is that your microphone is generation feedback when the talk because you have the speaker volume turned up. Try lowering the volume. If this doesn't work I suggest you use a set of headphones and it will eliminate this problem completely.
Hope this helps. Bud
Posted on Feb 05, 2009
bob_computer
  • 3153 Answers
SOURCE: sound and background music and noise is fine
This usually happens on home burnt DVD's
It is the format in which it was recorded that is at fault.
There is little you could do but re-encode the whole thing before you burn it.
Turn off or try the different surround options whilst it is playing.
If it does this with commecial DVD's then you may have set the surround setting by accident to somthing else.
I had a similar problem
Posted on Sep 18, 2009
Testimonial: "very helpful so far"
Obertelli
  • 3006 Answers
SOURCE: Background telly noise
This is a very common problem caused by poor design of the SCART system which allows cross-channel feedback.
At the TV rental company I worked for we cured it by supplying "cut" SCART leads; usually these leads are completely reversible, but on a cut lead one end is designated only for the TV.
They are commercially available and easily identifiable as one plug will be labelled "TV" and the other as "video" or you can make your own using one of the generic cheap SCART leads which allow you to open the SCART plugs to access the wires:-
Open the plug and identify pin 20. They will have moulded numbers, but pin 20 is the one which is in the angled corner of the plug. The wire should usually be pink, if it is green then check pin 19 which is directly above pin 20. If this wire is pink then cut it. If the pink wire was on 20 then label the plug as being for video/Sky, and if it was on 19 then it's must be labelled for TV. Now do the other plug, whatever the order of the pink and green wires on pins 19 and 20 was on the first plug will be reversed. Cut the pink wire again. If the colours don't match then just cut the wire from pin 20 (video/Sky) at one end and from pin 19 (TV) at the other end.
Reassemble everything and plug it all in correctly and your problem should be fixed.
On a slightly different matter, never waste money on over-expensive "upgraded" SCART leads. They may look good but you're just flushing money down the toilet.
I hope that this has solved your problem, all that I ask in return is for you to take a moment to rate my answer.
Posted on Feb 14, 2010
Testimonial: "excellent advice,thank you"
sarasvatas
  • 329 Answers
SOURCE: my acer aspire 4736Z webcam had a noise background
in control panel >> sound setting >> check wether mic boost is enabled or not if enabled then uncheck and disable the mic boost
Posted on Apr 07, 2010
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Background noise from a vertex pilot III
Increase the squelch control just enough to cut out the background noise.
Jun 25, 2012 | Vertex Standard Pilot III VXA-300...
Loud background noise
Have you already tried to lower the volume on the headset itself some steps, during the call, until you hear the conversation clearly?
Just my 2 cents... Carlos
May 12, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Background on my friendster
to search for backgrounds .. try
friendster-layouts.com
1. search for the desired background
ex: blue sky,skull,black.. etc..
2. now choose one of the given links..
ex: Black Layouts by Muspel . . normally its highlighted and underlined..
3. copy the css code.. ( the 2nd box below)
and paste it to your .. friendster Css ..
located in Customize profile .. 1st big box...
hope this helps.
Feb 15, 2009 | Plantronics BACKGROUND NOISE SUPPRESSOR...
Voices drowned out by background noise.
Not a suggestion, but I hope there is a solution.
Recently bought an LG HDTV that has a setting that should increase the voice over the background. If it does, I can't notice the difference. I guess they can probably measure it electronic.
I've had your same complaint for years, without a good solution. Best so far is to use headphones.
I have no idea why film people add all the extra noise. Most of it is not even real.
Dec 29, 2008 | Yamaha RX-V663 Receiver
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
