Question about Hitachi 43FDX01B TV
Turn off when I turn tv off at night wake up in morning it is on but not on tv it is on video 1 or 2 any help on what it might be? maybe relay?
  • mark alvarado Aug 06, 2007
    the tv comes on all by itself and when it is back on it is not in view tv mode it is onone of the video like 1 2 or 3. I did not want it on at all it just comes on
  • 398 Answers
If you mean that it happened once, then someone hit the INPUT button by mistake, either on the set itself or on the remote. Pressing the INPUT button will cycle through the tuner (A and B) and through all video inputs. Simply keep hitting the INPUT button until the set is back where it was before.
Posted on Aug 05, 2007
SOURCE:
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
Messenger won't wake up.
Try uninstall and re download messenger and install to see if that helps. Download Yahoo Messenger 11 5
Apr 14, 2014 | Yahoo Messenger
How does snoring a lot at night affect you in the daytime?
Some people snore at night but still wake up in the morning feeling like they slept well. But for some people heavy snoring leads to side effects such as;
1. waking up feeling exhausted the next day
2. difficulty concentrating
3. increased risk of high blood pressure, stroke etc
Snoring can also seriously impact on a partner's sleep as the noise can often stop the person sharing the bed from being able to sleep well.
Feb 13, 2013 | Health & Beauty
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
TV TURNS ON BY ITSELF IN MIDDLE OF THE NIGHT HELP
If you have eliminated the obvious things the tv must have a fault...
The obvious things - a night prowler with a remote, a cat walking across your remote, a ghost that likes to watch tv, somebody sleepwalking...
It is possible the infra red signal needed to switch on the tv is not coming from your remote. You can test this by removing the batteries or taking the remote to bed with you. If the tv still turns on then tape over the infra red receiver on the tv to eliminate the chance of some stray infra red beam from elsewhere being the culprit. If that stops the tv turning on you need heavier curtains or blinds or the tv moving perhaps, but if the tv still switches on it has a fault.
There is another thought. Digital TVs and digiboxes are often programmed to wake up periodically to check for software updates. Mine wakes up at 3am but it only checks for software updates and doesn't switch on the tv, but maybe this is what your tv is doing.
A further thought - a tv often has the functions of an alarm clock. They have a sleep function so they can switch themselves to standby after you have fallen asleep and then can wake you in the morning. Perhaps the alarm has been inadvertantly set for 2am?
These days it is rather anti-social to leave any appliance on standby. Rather than unplugging the set every night and worrying about the kids, why not arrange for the tv to be plugged in to a switched outlet so the kids can switch it on or alternatively use a cheap plug-in timeswitch to prevent the set switching on in the wee small hours...
Apr 16, 2017 | RCA F25442 25" TV
Battery being drained. Maybe be relays
Most likely the diode from the alternator is leaks draining the battery. If you believe your battery is good: 1- Disconnect negative cable from the battery over night to see how weak it is in the next morning. If it is bad then it is the battery no other thing. 2- If it is good, take off wires from the alternator for a night, next day battery is still good then there is a problem with the alternator diode. Hope this can help.
Nov 18, 2009 | 1989 Buick Regal
Charged it last night and now it will not turn on
Try a reset: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
May 02, 2009 | Apple iPod touch
"TV, turns it's self on"
Yeah Go Into Your Options Menu And Find The Wake Up See If Its Set To Turn Itself Off. I Use This When I Go On Vacation So People Will Hear The T.v On And Off At Intervals.
Jan 05, 2009 | Televison & Video
Ellas Mam Wont *** I Did make Her Fall Asleep But She Wpnt Ring Or ***
After you put Ellas to bed you must leave the bedroom and click on the moon for night to come in morning go back upstairs and wake Ellas hopefully after you dress her her parent will come. Hope this is helpful?
Aug 06, 2008 | Nintendo DS Lite Console
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Oct 09, 2007 | RCA 32V420T 32" TV
Hitachi 43FDX01B TV Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
