Question about Electrolux Washing Machines
How to drain manually EWT604S after using just the wash option?
I used the manual option of EWT604S and I would like to drain the after using the wash option only. How do I drain it?
2 Suggested Answers
  • 80 Answers
SOURCE: When I use my washing machine, water would not
The most likely cause of the problem is the back flow prevented seal has failed. The fact that your drain line is smaller than recommended, could be contributing to your problem by creating back pressure that is being released by your back flow prevented.
Posted on Jan 25, 2010
User manual ofelectrolux EWT604S
Try Googling (Electrolux)(EWT604S)(manual) without parens.
Jan 25, 2018 | Televison & Video
E4 always appears on the display of my electrolux ewt604s, what is the quickest solution to fix the problem?
http://www.electrolux.co.nz/Support/Manuals/?modeld=ewt604s
No easy answer.Electrolux does not recognise your model number or list error e4. I can only wish you good luck. and a few links that may help. Phone numbers and address at web address above.
If it won't open, copy and paste to your browser bar.
Electrolux Dishwasher Parts Accessories
electrolux dishwasher troubleshooting YouTube
Sep 13, 2014 | Dishwashers
EWT604s
The drain hose may be kinked. Slide unit forward to be able to see teh hose. Otherwise an electrical fault may not allow the drain relay to activate. UPLUG machine power first! Check if you have a diagram on the inside of rear cover. You may be able to discern when frain relay supposed to open. Check the drain relay to see if it energized at that point. BE carefull of electrocution danger.
Aug 13, 2014 | Electrolux Washing Machines
Electrolux ewt604s top load washer
how to install magic hose to faucet. it leaks like hell
Dec 24, 2012 | Electrolux Washing Machines
I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end...
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Oct 16, 2010 | Washing Machines
Won't spin cycle
when sitting for the last spin it may be out of balance,when you have no cloyhes in it,put 1cup of HE clorox bleach and let it sit in tub over nite,then run on heavy duty wash hot water cycle.(no clothes) this should open up drain pump.this may take several trys.
Jul 31, 2010 | Bosch Washing Machines
Aquarius 1000 rpm WMA30
One... use this option for...
Washing a single item of clothing, for example, one pair of jeans.
This option will reduce water consumption and washing time.
Note:You can reduce the amount of detergent you use with this wash.
Do not use the ‘One’ option with a full or a half load.
http://www.hotpointservice.co.uk/hs/pages/manual/
try this link for a manual
Aug 20, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Feb 11, 2008 | Washing Machines
Washing Machines Logo
262 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
