Question about HP Photosmart 3310 Printer
I can't copy documents using the front panel buttons
I can copy documents using my computer in the HP solution center. However, when I try to copy something using the front panel buttons a message keeps coming up saying that the paper size is not detected.
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 12, 2009
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  1. Make sure that the product is connected to the computer.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Scanning with an Officejet J3680
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click each program to include on the Scan To list.
Click the Add arrow.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
Apr 17, 2009 | HP J3680 Officejet All In One Printer
When I scan ,refer to device doc to troubleshoot .! light flashes
Is it giving you a message as NO SCAN OPTIONS in the front panel of your All-In-One...?
If yes and if the software is insatlled sucessfully in you computer then try the steps mentioned bellow.
If the software is not installed then you will have to install the software for your All-In-One First.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Oct 18, 2008 | HP Officejet 6310 All-In-One InkJet...
Scanner
Are you getting a NO SCAN OPTION
If you are getting this message when you are trying to scan from the All-In-One.
All-In-One printer.
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
If the software is not installed then you will have to install the printer driver and software sucessfully first.
Good Luck
Oct 12, 2008 | HP Officejet J5780 All-In-One InkJet...
Scannning photo
I hope you get this message when you are trying to scan fom the All-In-One stand alone machine itself and windows operating system...?
If then follw these steps mentioned bellow:
HP> HP Solution Center/HP Director) Then try scanning from there, if you are able to scan from there then try the steps bellow.
All-In-One printer.
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 28, 2008 | HP Officejet 4355 All-In-One InkJet...
Scanning
This message will come up when you are scanning from the Stand alone printer not from the computer.
If the software is sucessfully installed in your computer,
Then you should have a icon which says HP Director / HP Solution Center (If not Goto> Start> All Programs> HP and then you will see them
Open HP Director/Solution Center and try scanning from there, It should scan from there.
If yes then go to settings> Scann Settings> Scan to setup> There you see an option which says Front panel Destination list> Click that and there you see a options says Restore Defaults> Click that> then Apply and Ok> And close all the indows and try scanning from the All-In-One.
If it does not work then try the steps bellow:
Go To:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanner
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 04, 2008 | HP OfficeJet 6310 All-in-One Printer...
No Scan Options for HP Oficejet 6310
This is a resolution for "NO SCAN OPTIONS" in the front panel screen of the All-In-One Only:
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 03, 2008 | HP OfficeJet 6310 All-in-One Printer...
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Photosmart 3310 Printer Logo
41 people viewed this question
Ben Johnson
