Question about DreamCatcher Interactive Dungeon Lords demo
Dungeon lords window mode
How to play dungeon lords in windowed mode
How do you take screenshots in Dungeon Lords CE?
Find the PRINT SCREEN key on your keyboard and push it
Sep 21, 2013 | Computers & Internet
I need cheats of grand chase please
Here are some cheats. They may or may not work depending on the version of your game and platform.
Code: Effect:
timedown stop time during game play (dungeon only)
maxpmana Maximum Mana during game play (can be used in dungeons and PvP)
xhealthx No Effect on HP (dungeon only)
upupandaway High Jump (Dungeons and PvP)
stopattackbitches No hit Kill ( Dungeons Only)
moneymatters 100 000 GP per finished Dungeon
Chris
May 20, 2011 | Computers & Internet
Medieval Lords will not start on vista ... how do I start it?
The game is most likely not compatible with Vista. First port of call should be to try to run the game in compatibility mode, to do this all you have to do is right click on the shortcut on the desktop, click on "Properties" and then goto the "Compatabilty" tab then select the "Compatability Mode" option and from the drop down menu select "Windows XP". Try to launch the game again, if this doesn't work then try re-installing the game.
May 05, 2011 | Monte Cristo Medieval Lords for Windows
How do i run medieval lords on windows 7 ? please help im dying to play some classics
Here is how I managed to get it to work on Windows 7.
Download the patch at www.gspsupport.co.UK/media/patches/Medieval_Lords.exe
1. Save the file Medieval_Lords.exe to your desktop
2. Right click on the Medieval_Lords.exe on your desktop and left click 'Cut'
3. Go to C:\Program Files\Monte Cristo\Medieval Lords\BIN
4. Right click in this folder and left click 'Paste', this will ask you to replace the Medieval_Lords.exe , click 'Yes' .
5. Go to C:\Program Files\Monte Cristo\BIN\DATA\SHADER
6. Rename the file named StdMatDX8.fx.bin from "StdMatDX8.fx.bin" to "StdMatDX8.fx"
7. Run program as administrator
Hope this helps
Jan 18, 2011 | Monte Cristo Medieval Lords for Windows
Lord of the rings the battle for middle earth 2 will load on Windows 7 but will not play...it just sits and thinks....it gets stuck. Is there a patch or some solution? Thank you, otlakerat@tds.net
Try running the game in compatibility mode under properties. (Try XP SP3), and while you're in properties click the `run as administrator` check box aswell.
If that works then your game was probably just not meant to work with Windows 7.
Dec 23, 2010 | EA Sports Lord of the Rings: The Battle...
Medieval lords not running
Hello wilsonpaul74
As far as I know, there isn't a patch for Windows 7. Have you tried running it in compatibility mode? There are two ways to do this:
OPTION 1 - TROUBLESHOOT COMPATIBILITY
1. Right click on the programs shortcut, .EXE file, or installation program, and click on Troubleshoot compatibility. N.B. You will not have the Troubleshoot compatibility option available for pinned items in the Start Menu or on the Task Bar.
2. The wizard will now give you a list of options to choose from. Try each individual option, following the on-screen instructions.
If this doesn't work, you can try the following option.
OPTION 2 - THROUGH THE PROPERTIES PAGE
1. Right click on the programs shortcut, .EXE file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. Check the Run this program in compatibility mode for box.
5. Click on the drop-down menu arrow, and select which version of Windows the game was made for. N.B. Always pick the latest Windows version the game was made for a better chance of it running properly.
I hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | Monte Cristo Medieval Lords for Windows
Cant play old games such as dungeon keeper any ideas on how i can do thisi get blocks and fuzz
You can try and run the game in compatibility mode. You can do this by installing the game and then right click on the shortcut on the desktop/folder and choose properties. Click on the compatibility tab and choose the version of windows that you used to play it on.
The other option is to dual boot your operating systems. Infomation on how to get this done can be found here:
http://apcmag.com/how_to_dualboot_vista_with_xp__stepbystep_guide_with_screenshots.htm
Jan 22, 2010 | Microsoft Windows Vista Ultimate Edition
Video Game Consoles & Games Logo
192 people viewed this question
Top DreamCatcher Interactive Video Game Consoles & Games Experts
ray gallant
James Wishart
Are you a DreamCatcher Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
