Question about Woods Mechanical Inwall Timer 59017
Need wire diagram on a woods 59745 timer - Woods Mechanical Inwall Timer 59017
    New Friend:
I have a black and wht wire coming into my switch box and the 59745 switch has red black and wht wie on it how do i wire this in
Posted on Jul 16, 2013
How do I wire a Woods 59402 timer 240v input running two 120v outlets
Woods 59402 timer wires identical to Intermatic GM40, with same ratings and dip-switch settings.
http://waterheatertimer.org/How-to-wire-GM40-timer.html
Here is specific wiring diagram per your request, showing 240Volt input controlling two 120Volt outlets.
http://waterheatertimer.org/images/GM40-wiring-240v-120-volt-5.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
Keep in mind that with 240Volt, both hot wires coming from breaker box carry 120Volt each, with 240Volt potential across both hot leads.
Each 120Volt Hot from breaker box, also carries 120Volt potential to Neutral or ground wire.
So the 240Volt wires from breaker box can supply the Hot for a 240Volt circuit, but the circuit must also have a neutral wire to complete 120Volt circuit.
Be mindful that timer is not 2-channel, so both outlets are controlled by same timing schedule.
If you want two different schedules for the outlets, then buy a 2-channel timer like Intermatic ET1125. Wiring for ET series remains similar to illustration link above.
Dec 01, 2012 | Coleman Cable Woods 59402 40Amp Timer for...
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
Lost wiring instructions for my woods water heater timer. What wires attach to bus bar
Timer model is usually located inside the door panel:
1) Open following link to access manual with wiring diagrams.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Boxtype
2) Example manual shows different wiring diagrams:
http://waterheatertimer.org/pdf/Woods-59396-59399-manual.pdf
If you have timer with 8 terminals, and ordinary 240V water heater, then use diagram on bottom right.
3) Woods timers are wired identically to GE 15207, except your model might not have dip switches.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
4) Busbar usually refers to a long metal bar where many wires connect to same pole. For example neutral busbar inside breaker box has 20 or 30 wires connected to it, and all are connected to Neutral wire from power pole.
http://waterheatertimer.org/B220C.html
5) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Kitchen Ranges
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
The old timer that was there quit working tryed to put a new woods one in but cant get it to work help
The following wiring diagram works for Woods, GE, Hagar, Leviton, Sylight, Utilitec, some Intermatic in-wall timers.
It does not apply to Aube timers or Intermatic battery-operated timers.
If the wires are not connected correctly, the timer will not operate as expected.
Click the manual override and see what happens.
If the lights do not turn ON with the manual override, then the wiring is suspect.
If the lights blink, then you have put the red and white wires together.
If the lights turn ON, but timer clock is not working, it is possible you have the black and red wires reversed.
If the white wire is not connected correctly, the clock mechanism will not operate.
Review the wiring.
Black-timer wire goes to black-hot-wire from breaker
Red-timer wire goes to black-wire going to Load (lights)
White-timer wire connects to the Neutral wires that are usually twisted together and covered with a wire nut.
IF your box does not contain those white wires, then you can work-around by connecting white wire to bare ground wire.
Nov 02, 2010 | Woods 59028 Programmable Timer Switch...
How do I wire the timer in a 3-way switch?
Woods 59013 59017 59018 59720 59028 etc wall timers are not made for 3-way application. They replace a simple on-off switch.
Atube T1032-3W programmable timer shows it can replace 3-way switch.
See manual
Smarthome
Intermatic ST01C & EJ500 programmable times can replace 3-way switch. Look at diagrams carefully. Circuit is limited to 100' distance because of battery.
See wiring diagram
Aplus
Lutron makes several 3-way countdown timers that turn on light for certain length of time and then turn off light
Tip for 3-way switch replacement: Mark wire that connects to dark-colored screw. This is called the 'common' wire.
Depending on location of switch, the 'common' wire either goes to Load (lights) or it comes from breaker box as Hot wire.
Oct 02, 2010 | Woods Hardware & Accessories
Wired incorrectly need wiring diagram
I have baxi combi boiler genesis 80 and grasslin timer need to no what wires go were there are 4 wires coming out the timer red and brown together white and blue the timer is internal one can you help
Mar 18, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Woods Mechanical Inwall Timer 59017 Logo
316 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
