Question about Samsung 2.0 cu ft Over-the-Range Microwave Stainless Steel SMH9207ST
Se error code on smh9207st - Samsung 2.0 cu ft Over-the-Range Microwave Stainless Steel SMH9207ST
How to reset an error code of SE on a samsung microwave model SMH9207ST
May 24, 2017 - SMH9207ST
There's no reset for it, but you can find the two solutions on my page here: http://www.microwavecontrol.com/samsung_se_error.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Apr 19, 2017 | Samsung Microwave Ovens
What does se mean on Samsung over the range microwave model #smh9207st
The SE error code means a key has been depressed for more than 10 seconds. Press the "Clear" button, does it reset and work normally? If not, try completely cycling power to it. If that doesn't work you will probably need to replace the touch pad assembly.
Aug 02, 2016 | Samsung Microwave Ovens
Samsung microwave smh9207 SE Error, there is no ribbon wire on circuit board.
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Nov 16, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
Here is the product# SMH9207ST?
Check here for warranty info:
Warranty Information Samsung UK
If you are outside the warranty period you may find repair instructions online if you type the nature of the problem into Google, or give more specifics on the actual problem, like no heat, or no power etc. maybe we could help more, with pointing you to replacement parts etc :)
Jul 14, 2014 | Samsung Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
Open Questions:
See all Samsung 2.0 cu ft Over-the-Range Microwave Questions
Samsung 2.0 cu ft Over-the-Range Microwave Stainless Steel SMH9207ST Logo
366 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
