Question about Nortel AL2500E01E6 2526T 24PORT 10/100 2PORT 10/100/1000BT SFP 2PORT Transceiver
What is test internal loopback failed nortel and which component faulty
How do I fix voice mail and auto attendant features lost on Nortel Norstar mics 4.1
You can restore a recent configuration backup from diskette but if you don't have a backup you will need to rebuild the configuration from scratch. You may also have a failed hard drive or a failed supercapacitor that did not retain memory when the power was cycled. These components will need to be replaced before you continue with reprogramming.
Apr 25, 2014 | Nortel Norstar Modular ICS MICS 4.1...
01 vw Jetta trubo 2.0 code p1113
Trouble Code: P1113
O2 Control (Bank 1 Sensor 1) Internal Resistance Too High
Possible Causes:
Oxygen sensor (before catalytic converter) is faulty. Oxygen sensor (behind catalytic converter) is faulty. Oxygen sensor heater (before catalytic converter) is faulty. Oxygen sensor heater (behind catalytic converter) is faulty. Circuit wiring has a short to power or ground. Engine Component Power Supply Relay is faulty . E-box fuses for oxygen sensor are faulty . Leaks present in the exhaust manifold or exhaust pipes. HO2S signal wire and ground wire crossed in connector . HO2S element is fuel contaminated or has failed. ECM has failed .Here is what is listed.
Sep 05, 2012 | Volkswagen Jetta Cars & Trucks
Philips 50PF9630A/37 plasma TV will not power on and has a red blinking light - 6 slow flashes then 3 quick flashes . I've been having the issue on and off for about 2 weeks. seems like when I ...
Hi.
The TV is forced in standby because an internal fault has been detected. 6 blinks slow and three fast blinks points at defective Ysus board or defective buffer. The power supply must also be tested. Till now the TV was starting because when you disconnect power you discharge internal components. Some of the components have the role of storing charge (the capacitors). If a capacitor is defective the TV may still work as other components will compensate the function of the faulty part. After a while more components will fail and the TV will not start anymore. To fix the problem the TV must be tested at component level. Testing will start from PSU voltages to YSus and buffer boards.
Regards.
Ginko
Aug 04, 2011 | Philips 50PF7220A Television
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other...
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Dec 09, 2009 | ViewSonic VA902b 19" Monitor
Loopback failed - 127.0.0.1 blocked - web page test not possible
Please explain:
Does it work if you use http://localhost?
Does it work if you use http://127.0.0.1?
If the first one does not, but the second does, it is possible that the issue can fixed simply by selecting.
IE-->Tools-->Options--> Connection --> LAN Settings Check Bypass Proxy for local addresses
If you can't telnet into your computer, make sure you have the Telnet service running :
  1. Click Start, then Run, and type "services.msc" (without quotes) and click OK.
  2. Find the "Telnet" service, right-click and select Properties, select "Automatic" instead of "Disabled" in the startup type box.
  3. Click Apply.
  4. Right-click the "Telnet" service and select Start.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Zyxel Prestige 600WH Wireless Router...
T.v.shuts off.
This television is experiencing a component breakdown. This is probably from a overheating problem. The break down component is probably a capacitor. The component has lot its ability to control it operations.When it fails the television goes into the protection mode. This allows the component to cool down and to heal itself temporarily. This will not last and you will need to have the television test for faulty components.The repair of this should not be too expensive.You should call a service center and ask for a estimate of the repair cost before taking it in to be repaired. You may be able to do the repair if you have some experience working with electronic test equipment and tools. you will need a large work space, screw drivers, soldering iron and some test equipment.A digital multimeter will be needed to test some components, if a solid state component has become faulty. Usually a diode or transistor.The repair will require good soldering techniques.you must visually inspect the circuit boards and replace faulty components as found. Remember these are high temperature components and need to be replaced with the same high temperature ratings. You may want to try cooling the television with a constant cool air flow to save it from further damaged. I hope this information helps you with your problem.
Mar 09, 2009 | Quasar SP-3235 32" TV
V.35 Cable Local Loop
If your trying to establish a loopback for the Data Terminal Equipment, you seem to have satisfied the RTS/CTS, DTR/DSR loopback. At the V.35 end of your cable, you need to loopback the SD (balanced pairs) to the RD (balanced pairs), as well as insure that you have a valid clock source. Usually the DCE provides clock on a balanced pair SCT, SCR. towards the DTE. But, when you build a loopback cable or adapter, you can obtain clock from the DTE via the SCTE pair and tie it to the SCT and SCR balanced pairs. A lot of the requirements depend upon the DTE and DCE equipment your testing. Hope this helps...
Dec 09, 2008 | Cisco router cable, DB-60 male to V.35...
NIC too close to USB port?
Hi Antatg,
Go into your bios and make sure all your USB option are enabled, specially Enable USB for legacy devices, and check to make sure you NIC is enables. Hope that helps!
Good Luck!
Jan 07, 2008 | Dell Dimension 1100 PC Desktop
I 560
Sounds like the microphone in the handset came loose or went bad. Turn the phone off. Press and hold buttons 1, 2, and 3 while turning phone back on. This puts you in self test mode. Follow instructions on screen until you get to audio loopback test. Put phone to your ear and talk like you normally would. If test fails the mic is bad. Take it in to a service center.
Oct 12, 2007 | Motorola Mobility i560 Cellular Phone
Nortel AL2500E01E6 2526T 24PORT 10/100 2PORT 10/100/1000BT SFP 2PORT Transceiver Logo
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
