Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door works sometimes and sometimes it won't
The remote seem to be working fine. But sometimes when I try to open the door it only goes up half way or part way. Closeing the door is never a problem. The door seems to be difficult when the temp is on the rise. I live in Iowa and right now it's cold, door working fine. I've tried to adjust the chain, up and down tention on the motor. Nothing works for very long. Can you offer and help. Larry
  • 102 Answers
Spray some silicone in the tracks...this should help...it sounds like an alignment problem
Posted on Mar 12, 2009
How do I change the frequency of a garage door opener 139.53930ODM?
Hi... You have to "erase all codes" (you can read that section of the manual and teach the opener to use the remote using a new code. You can get the manual at the Craftsman site, page 35. Essentially you do this: access the reset button n the back right of the motor, press and hold the 'learn' for 6 seconds or more,until the learn light goes off. TO reprogram it, press the learn button until the light goes on, then within 30 seconds, press and hold the desired button of the remote. Voila!
Dec 26, 2014 | Chamberlain Liftmaster 355LM 315MHz Garage...
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
The door will open just fine, when closeing the door (by the wall switch) it will not close unless you hold the buttom down. The sensors at the bottom of the door has a green light on one side nad the...
Your door switch is bad. You can get one at home depot, it's nothing more than a door bell button. Your lights are correct and I bet if you try to close with your remote it works. That also will verify it's a bad button.
Mar 01, 2011 | liftmaster Chamberlain Garage Door Opener...
Driver's side back window not working. I checked the window motor and it working fine. What next?
check wiring from drivers door to inside of car, wires sometimes split in half from door opening and closeing so much, if wiring is ok, the master contorl switch on driver door is bad.
Oct 02, 2009 | 2002 Ford Taurus
Last night none of the remote controls worked (the one that came with the garage door opener or the remote Home link from our vehicle) The keypad also did not work. This morning, I erased all of the codes...
First thing I would do is remove the wire from terminal #1 on the rear of the motor unit and try your remotes. This wire goes to the wall control and it sometimes causes the remotes to quit. If this doesn't correct the problem then I suspect a bad logic board. Especially if you have had any electrical storms.
Aug 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
376 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
