Question about Kenmore Vacuums
Kenmore 23401 bagged with hepa - Kenmore Vacuums
Where can I get part # KC38KCEN1000 HEPA FILTER FOR MY KENMORE CANISTER
I would think you should be able to get it at your local sears store or go online to www.partsdirect.com
Feb 27, 2012 | Kenmore 23913 Progressive PowerMate Bagged...
Should the arrow point in towards vacuum or out on the replacement exhaust hepa filter for my kenmore prgressive 400 series vacuum?
I'm assuming the arrow you are referring to is on a new dust bag. If that's the case, the arrow should be pointing down toward the bottom of the machine.
Jim Hart
Jun 20, 2010 | Kenmore 34613 Bagged Upright Vacuum
How do you change the bag in a kenmore progressive true hepa canister vacuum?
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
I have a kenmore cannister vac - model 27514. Do I have to use hepa bags in it, or can I substitute another type, and which would that be?
You know, any bag made for the unit should give similar results. You can buy a cheaper bag and that number is 50558. You can get them at your local vac shop or you can let me know, I will send you some. The price per 3 pack is only 4.95. The canister vac is made in such a way that it doesn't have much leakage. It is quite efficient with or without hepa bag. If you or anyone in your family suffer from asthma, I would recommend the use of the hepa bags. tThanks, Rene(The Vacuum Doctor)
Nov 10, 2009 | Vacuums
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
98 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
