The washer goes to LE and flashes. Then the washer stops.
    Problem Solver:
  • 17 Answers
Could be 1 of 2 things your washer nds a reset try unplugging the washer leave unplugged for 5 minutes replug start your machine Your drum may be out of line when it starts to wash it jumps off if that's it u will nd to call 4 service
Posted on Aug 29, 2014
4 Suggested Answers
  • 100 Answers
SOURCE: LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
Posted on Oct 30, 2007
MNTECH
  • 1543 Answers
SOURCE: My LG washer is flashing LE and won't contiue the
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Sep 06, 2009
richroth
  • 9472 Answers
SOURCE: once washer goes in cycle it stop and you hear a buzzin noise and washer stops and LE light comes on
Take a look at this link.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6250
Posted on Nov 14, 2011
Washer stopped, door is locked and LE is flashing on machine. What should I do?
it has detected a problem with the fill water
as the official description of the "LE" is:
The washer has tried to fill but has not reached the proper water level.
there can be several reasons for this to occur , the only one that the operator can ck is that the water supply to machine is connected and turned on , the others are a serviceman's call
Jan 18, 2016 | Samsung WF337AA Front Load Washer
WHAT DOES IE STAND FOR?
LE = MOTOR IS BLOCKED
Faulty open circuit wiring to stator assembly.
Sep 20, 2014 | LG WM2688HWM TROMM SteamWasher
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Mar 15, 2013 | LG WM2101HW 4.0 cu.ft. Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Sep 06, 2009 | Washing Machines
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
Shows "LE" in display.
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
LE code
Oct 30, 2007 | LG WM-1832C Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
