Bauhn set top box locks up on channel 9,remote not responsive,tried to un plug unit no longer works
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Posted on Apr 22, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
SOURCE: Channel up/down no longer works.
I reinstall the latest firmware and it solved the problem.
Posted on Apr 07, 2009
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Posted on May 09, 2009
Hi I have a Bauhn AC42 F22 which the remote has been broken and have bought a new remote but can not find the code for the new remote . Appreciate your assistance . David
Better to buy a facsimile remote
bauhn - Remote Control Warehouse
https://www.remotecontrolwarehouse.com.au/bauhn-c185
Add to Compare. REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415 ATVU65-0916 LCD TV. Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N Suitable for BAUHN Models: .. $38.50. Ex Tax: $35.00.
REPLACEMENT BAUHN REMOTE CONTROL - ATV185-014 AT215D ...
https://www.remotecontrolwarehouse.com.au/replacement-bauhn-remote-control-atv1... Generic BAUHN REMOTE CONTROL Unit: ATV-32HDC1N. Suitable for BAUHN Models: ATV-32HDC1N ATV-24LEC3 AS-39FHD1 ATV-50FHD5. ATV185-014 AT215D-0216 ATV32-715 ATV32H-014 ATV32H-1215 ATV40-014 ATV50-014 ATV50-715 ATV50F-415. ATV40-1014 ATV40-1015 ATVU65-0916 ATVUHD55- ...
Or their own Universal Remote
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Manual.pdf
The Codes are in the PDF File
http://winplus.com.au/links/UR39677%20Bauhn%20Universal%20Remote%20Code%20Book.pdf
Mar 14, 2018 | Televison & Video
I need a manual for a Bauhn 2.0 Channel Soundbar
D Ponto... hello,
Any 2.0 manual will work(?)... or you want us to
actually define all the 2-channel possibilities for you
(perhaps with pictures)...?
((not happening... not even for money)).
My favorite manuals website responded with
quite a few Bauhn models...
Since this is really a GLOBAL site... MODEL NUMBERS
come in really handy to try to give serious answers...
Have a look at the PRELIMINARY (Domestic USA)
responses... Perhaps something might ring a bell.
For a SERIOUS (even free) answer...
Results for bauhn 20 channel soundbar var myCallback function document...
Break a sweat... Find your model number.
Carnac the Magnificent
Aug 06, 2017 | Audio Players & Recorders
Need installation instructions for GVA 100 set top box
Just bought one of these cheap.
Very basic just plug in and it sets itself up to some degree.
- make sure tv is on appropriate AV channel as you'll need the on screen menu to set it up initially using the remote control.
- then set the unit to scan for the tv channels, took about 10 minutes for me.
- NOTE ... there is no power on/off switch. Plug the cord into the 240v outlet and unit comes straight on. You can't turn it off except by switching offf at power point. Or using the standby button on the remote.
- NOTE ... there is also no display on the unit. So yoy have no channel display on the unit. It is all done on the tv screen.
But it does have quite a good EPG and menu guide.
For the price, can't complain.
Jun 04, 2011 | Televison & Video
TV freezes up when turned to channel 33-1
I had the same problem. I also use rabbit ear antenna , no cable or satellite. I was watching ch. 33.1 and the tv turned off by itself. The remote wouldn't work. The power on/off buttons on the side of the tv wouldn't work. I had to un-plug the power cord to turn the tv off. The tv forze on ch. 33.1 when I turned it back on.
I called Vizio, they told me they received hundreds of complaints from people in Texas complain g about these problems.
I was told to un-plug the antenna cable and re-plug it. I did this plus I re-scanned all channels. The problem has been solved, the channel (33.1) no longer freezes and the tv doesn't turn off by itself.
Hope this helps.
Aug 22, 2009 | Vizio VW32L 32 in. LCD HDTV
When on the digaital converter says no signal
Depending on type of antenna you have on the box the signal maybe too weak. But first try to lock channel 03 into your set. go to menu and add 03 where it has add/delete channels. If this still does not work select channel 04 and set your converter box switch to channel 4. This should do it.
Jan 18, 2009 | Sony RMT-V202 Remote Control
Unable to select channels using the unit
First, test to make sure the Philips remote is working by trying to play a dvd. If the remote control is working, then either A) your TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
Dec 25, 2008 | Philips DVDR3576H DVD Recorder
Channels won't stay setup
Sounds to me like a stuck button on the set or the remote. Once you get the channel set up straightened out you should be able to work on the V chip issue. Do you have the manual?
Nov 21, 2008 | JVC AV-32050 32" TV
Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
Oct 22, 2008 | 1996 Ford Explorer
I have a centrex CTDV100 set top box that has lost all its channels. Rescanning only finds SBS channels - ie no ABC, 7, 9 or 10. I've reset to defaults and rescanned but no change.
HI
I have a remote that stopped working could I purchase yours, alternatively I could email pages from my manual so you can try to have your box work again
Lindsay
Apr 19, 2008 | Televison & Video
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
