Question about Maytag 24 in. MDB9750AW Dishwasher
Not cleaning I have a 100 (not so) quite series dishwasher that does not clean worth a ****. Water spots, food left on dishes ect.. Any idea's?
  • Maytag Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Sep 29, 2010
Spots on dishes
It depends on the kind of spots.
Hard water spots are just the result of minerals that were left behind when the water evaporated.
Food spots can be the result of food that was allowed to dry before putting the dishes in the dishwasher.
In general, a water softener can be quite helpful in reducing hard water spots, and can also help the dishwasher perform better.
Note too that recent changes in the formulation of dishwashing products has been a problem for people who do not have water softeners. Government mandates have recently restricted addition of phosphates in dishwashing products in many states. Phosphates were quite beneficial to the dishwashing process.
A water softener may be your best answer.
Mar 06, 2011 | Frigidaire Dishwashers
Dishwasher not cleaning food is still on dishes
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Oct 28, 2010 | Kenmore Dishwashers
My dishwasher leaves a white chalky film on the dishes after washing
Oct 27, 2010 | Whirlpool Dishwashers
Food residue is building up on my dishes. i have put CLR through it to clean it out. is there something else i need to do
Oct 03, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
My Seimens dishwasher is not cleaning the dishes properly. When I take them out hey are covered in bits of food. Any suggestions please
Sep 30, 2010 | Siemens Dishwashers
Film left on dishes
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Aug 31, 2010 | GE Nautilus 24" Built-in Dishwasher
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 | Dishwashers
Maytag 24 in. MDB9750AW Dishwasher Logo
91 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
