Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Lg dishwasher 1204W1 not cleaning - LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
2 Suggested Answers
  • 3 Answers
SOURCE: LG DISHWASHER LD-1204W1
Try turning your tap off a bit till the noise stops but the dishwasher still fills, it can just be due to a bit too much pressure on your water valve.
hpe this helps
Posted on Apr 21, 2008
Power is on will not start
door switch probably failed
Sep 19, 2015 | Dishwashers
Where are the filters on an lg dishwasher?
Your dishwasher may have a filter located near the bottom or under the lower spray arm. This filter should be inspected and cleaned regularly. Follow your dishwasher owner's manual for specific instructions about how to properly remove and clean this filter, if equipped. If there are any holes or other damage to the filter, you'll need to replace it immediately to protect the dishwasher's pump and motor seals from damage.
Jul 03, 2014 | LG 24 in. LDF 7811 Stainless Steel...
E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
L.G DISHWASHER E1 ERROR...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it.
Jul 21, 2011 | LG Dishwashers
My LG 1204W1 door will not close. The latch in the inside of the door at the top seems to be 'locked' making the door bump on the metal part that sticks out from the top of the door frame on the...
Hi there Bushx, sound to me like the door latch is in the closed position. you should be able to feed something into the catch and pull it back out to the open position. Please let me know if this helps regards Gary
Jul 17, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher smells
Please perform an vinegar clean cycle on your dishwasher..Pour a half cup of vinegar into the bottom of the dishwasher and run a cycle at the highest temperature possible.Run the complete cycle.. Also clean the dishwasher filter for debris if any.
Dec 10, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher is making loud grinding sounds
debris in pump. unplug and disassemble pump. clean out and reassemble
Aug 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
Ld-1204w1
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
Oct 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
hpe this helps
Apr 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Drain Cleaning
Belive it or not if you delime the machine it will clean the whole system.Goto a supermarket,kmart,walmart and find clr (calcium lime rust) remover.Pour 2 cups into the dishwasher and start a cycle.Do this 1 time a month.It will keep everthing clean (hoses,probes,floats,screens).It comes in a grey bottle and costs about 8-10 bucks.
Nov 15, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
18 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
