Question about Casio Office Equipment & Supplies
Casio FX 300SA out of scientific notation
I have tried the solutions proposed here for the calculator. Pushing the mode buttons has no effect on the SCI selection, nor does there appear to be a FIX or Clear button to push.
5 Suggested Answers
Shakeel786
  • 27 Answers
SOURCE: FX-55 Calculator: how do I clear my casio scientific calculator from...
press the "MODE" button 3 times and then press 3 ..., now this is normal mode
Posted on May 21, 2010
  • 8068 Answers
SOURCE: Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Posted on Jul 18, 2010
SOURCE: How can I get my
Please press the Mode button on your calculator repeatedly till you get the following screen
Fix Sci Norm
1 2 3
Press 3 from your keypad and the screen will change to
Norm 1~2?
Press 1 from your keypad and your calculator will be normal again i.e out of scientific notation mode.
Posted on Mar 16, 2011
  • 8068 Answers
SOURCE: Casio FX-115ES Scientific Calculator
I have done the calculation using the the shortcut key [x10^X] to enter the exponent,and I got the correct result.
I also did the calculation by explicitly typing the 10^10 factor and I obtained the correct result.
The syntax error may come from your using the minus - sign for subtraction rather that the change sign key (-)
Posted on Apr 07, 2012
My calculator will give me an answer in scientific notation. How do I change it to decimal form?
To switch out of scientific notation, press SHIFT MODE then select Fix or Norm.
Be aware that the calculator will switch to scientific notation anyway if the magnitude of the answer is too large or too small.
Aug 24, 2014 | Casio FX-115ES Scientific Calculator
How to turn off scientific notation on casio fx 300 es
Press [SHIFT][MODE] (Setup). and select some other display mode such as NORM.
Jun 15, 2014 | Casio FX-115ES Scientific Calculator
You have the calculator set to Polar notation. In Polar form -2.16 is 2.16 angle 180. To get out of this, press SHIFT MODE down-arrow 3 1 .
Jul 29, 2012 | Casio FX-115ES Scientific Calculator
I know the S<->D button that it will change from fraction to decimal, but my calculator happens to change from fraction into scientific notation! i did what the others said to Press SHIFT MODE 2 to...
You want to change the display mode. Press SHIFT MODE. Then press 6 and a number specifying the number of digits after the decimal point for fixed decimal notation, or 6 and 1 or 2 to specify one of the floating point modes.
Sep 18, 2011 | Casio FX-115ES Scientific Calculator
How can I get my calculator out of scientific notation mode? It is a casio fx 300ms
Fix Sci Norm
1 2 3
Norm 1~2?
Mar 15, 2011 | Casio FX-300MS Calculator
I cant get my casio out of scientific notation
Press SHIFT MODE and then 8 for Normal or 6 for Fixed decimal notation.
Feb 01, 2011 | Casio FX-115ES Scientific Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
Apr 16, 2010 | Casio fx-300ES Calculator
How to change or put math mode without fractions or scientific notation on calculator fx-155 es natural display
Press SHIFT MATH 2 to switch to the LineIO mode. You won't see fractions then. However, if magnitude of the number is too large or too small, the calculator will switch to scientific notation in order to fit into the display.
Mar 22, 2010 | Casio FX-115ES Scientific Calculator
Is there a way to fix the casio fx 260 solar to display numbers in scientific notation Like 3 x 10(raised to the 2nd power)?
This can be done by setting the calculator to the right MODE. Press MODE 9 to turn on scientific notation. For example, compute 1 / 200 = and you will see 5 with a -03 exponent in the upper right. Press MODE 9 again and it will be displayed .005
To enter numbers in scientific notation use the EXP at the bottom. To enter .005, press 5 then EXP then +/- then 3. You will see it displayed. Then you can perform calculations with this entered number.
Oct 01, 2009 | Casio FX-260 Calculator
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
