Question about DeLonghi Heating & Cooling
My delonghi heat/air unit has a exclamation point & will not turn on
Hi, my delonghi manifica 4200's infuser is stuck high up to the right and is completely stuck, tried moving motor etc after reading fixes on here but it's not moving at all. Any advice please? Neil
leave the power point turned on.
turn off machine at the power switch (on the unit)
This should bring the unit down....or
Turn off completely unit and power point and the just turn on the power point...this should bring the unit down
Nov 14, 2016 | DeLonghi Coffee Makers & Espresso Machines
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
The DeLonghi PACA130HPE 13000 BTU Portable Air Conditioner unit will not function. Unit displays the Alert symbol only and no other designation as identified in the product manual. The unit was in heat...
I had the same problem, you have to empty the water pan in the rear of the unit. In the heat mode it will NOT evaporate the water like in the air conditioner mode. If you use it a lot in the heat mode and have a lot of moisture in the house you will have to modify the water outlet to have it constantly draining in a pan or out of the house.
John
Oct 09, 2012 | DeLonghi PACA130HPE 13000 BTU Portable Air...
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
Selonghi pinguino super pac 26 works fine for about 20 min the turns off with the warning light that is the same as the power light flashing. How can this be fixed as apart from that it is fine. I did...
I had the same problem. Except it only lasted 10mins. It turned out that the water pump was not moving enough (any actually) water to cool down the heat exchange unit. The unit turns off if it overheats. I pulled the back off and realised that the water resevoir container was full of lime & calcium scale. Some of that had obviously got into the impeller blade in the water pump. I removed the water pump & hose and discovered a lot of hard crud in there. Cleaned it out, reassembled and hey presto the water was flowing agin and the heat exchanger was happy. Problem Soved. Anthony
Nov 21, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Apr 16, 2009 | DeLonghi Heating & Cooling
Need a manual for the Delonghi Dragon HM25E
Try Googling (Delonghi)(HM25E)(manual) without parens.
Dec 20, 2017 | DeLonghi HM25E Oil Filled Radiator Heater
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
