Question about BeamsWork 36"-40" Double Bright Power LED Aquarium Light Fixture 2600
Are beamsworks dimmable - BeamsWork 36"-40" Double Bright Power LED Aquarium Light Fixture 2600
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
My ikea 365 lunta floor lamp (dimmer) won't work?
What type of bulb are you using? It will only work with bulbs that are dimmable and not all bulbs are dimmable. Look on the light bulb's package to see if it is rated as dimmable.
Jul 12, 2014 | Home
Where could i find the dimmable t8 led tube for a good price?
You can buy T8 LED tubes from Lumenorenergy because its a solid state lighting manufacturer and retrofit company specializing in commercial and residential lighting upgrades. Buy from here : http://www.lumenorenergy.com/
Dec 07, 2012 | Audio Players & Recorders
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
BeamsWork 36"-40" Double Bright Power LED Aquarium Light Fixture 2600 Logo
81 people viewed this question
Top BeamsWork Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a BeamsWork Fish Expert? Answer questions, earn points and help others
