Question about ViewSonic VA1926w 19-inch Wide LCD Monitor
How to connect viewsonic va1926w to ps3 - ViewSonic VA1926w 19-inch Wide LCD Monitor
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
My new PS3 wont seem to connect to either audio or video connections? is there a general problem with this tv model? i tried both the R/L audio's and for the yellow cable i tried that in all of the...
Sometime the game cable connections itself have bad conductivity and shorted,tries twist and shake the cable u hear humming audio and see flashes of picture in and out?Tries hook it up with a single HDMI cable cord,have a more success with many LCD tvs models.U have a HDMI cable or try Ebay.com,Amazon.com to buy one.
Jun 01, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Im playing my ps3 in my viewsonic vx2250wmled but the speakers wont work
do you connect the audio cable from your PS3 to Viwesonic LCD. if not connect the cable at th PS3 on audio output and at LCD in audio input.
reply me if problem is not resolved
Jan 17, 2011 | ViewSonic Vx2250wmled LCD Monitor
Trouble connecting Ps3 to Viewsonic N3240W Via HDMI cable or RCA / AV ?? No picture... How to get it to work ?? NEED HELP ASAP !!!!!!!!!!
Just had this problem myself.
Has been solved by connecting PS3 to a working monitor.
Go into video output settings on your PS3 and selecting a video output that is no more than the maximum resolution of the new monitor you wish to use.
Eg. 576p or 720p
Oct 11, 2010 | ViewSonic N3240w 32 in. LCD TV
My LCD viewsonic VA1926w has a problem. It has a power and the led near power button in orange color. The problem is the display is blank. Don't see anything.. Thanks for help.
First, try it with another PC since orange light means it is not getting the video signal from the PC or bad cable, or something inside failed.<br /> If it still does not work, then you will have to open it up and look for bad DC filter caps first.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | ViewSonic VA1926w 19-inch Wide LCD Monitor
I connected my ps3 to my viewsonic vx2235wm and it says out of range or wont have a picture
The PS3 video output setting is too high for the monitor to handle, native resolution for this Viewsonic is 1680x1050. Try running the PS3 at 640x480 first and start changing the resolution to higher level.
Mar 25, 2010 | Computers & Internet
Viewsonic VX2265wm 12o Hz monitor
That's a lot of information and possible problems areas. You need the driver for the Viewsonic screen first of all.. Why do you need to drive the screen at that frequency? you won't notice anything above 85Hz anyway.. I am assuming you have the correct drivers for you video card adn that it is correctly configured for the resolution and frequncy. That video card can drive high resolutions adn high freq's. But if you're only getting those two options then it appears to be a driver option. Get/load the Viewsonic screen driver first.
May 04, 2009 | Computers & Internet
Ps3 trouble
ok, i got it working... Ok...your problem is probably that when you're using it on the HDTV...you have the resolution set to an HD one (720p, 1080i, 1080P). A normal TV cannot display these. While it's connected to the HDTV,Before you connect it to your normal tv, you have to switch it back to 480i or 480p otherwise, your regular tv wont show a picture. So go to settings, display settings, and uncheck 720p, 1080i, 1080p. It will ask you if these are the settings you choose (and it's going to look funny on your HDTV) Accept the settings and turn it off. When you connect it to your Regular TV, you should now see a picture. Hope this helps!
Dec 13, 2007 | ViewSonic N2060w 20 in. LCD Television
ViewSonic VA1926w 19-inch Wide LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
