Question about Milwaukee M18 Compact Drill & Impact Driver Combo Kit 2691-22
When pulling trigger impact runs then it stops then it may work again
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Throttle valve is rotten and tool runs when you plug in the air without pulling trigger
there is a neoprene O ring in the trigger area ,that breaks down ,it needs a service by an air tool repairer ,it is not expensive. dont use wd40 or the like if dont have airtool oil use auto transmission fluid and this wont happen too often
Oct 18, 2009 | Craftsman 1/2" Impact Wrench
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
It does nothing
Make sure that you have at least 50 psig of air pressure before you attempt to troubleshoot your impact. 70 is better, 90 is perfect. Impact wrenches are powered by internal sliding vanes, which can sometimes stick. There are a couple of ways to get it going again. Try 1 before going to 2, etc,:
1. Spray W-D 40 or a similar oil into the impact, while you are holding the trigger down. Give it a good shot. Connect the hose and pull the trigger. Tap the sides of the gun with a plastic hammer to help free up the vanes. Repeat. Normally, this is enough to get you back running.
2. Place it in a bucket and cover the gun with W-D 40. Work the anvil end and trigger to work the oil deep into the gun. Ley it soak 1 hour, and repeat the process, working the oil in, and the air out. Remove it from the oil, and drain the oil back into the bucket by holding the trigger down. Hook up the air, and blow it out.
3. Remove the cover on the head that covers the vanes. Make sure that the vanes will slide freely, and that all gaskets and "O" rings are in good condition. If you note any dry areas in the inner parts of the impact, lubricate with W-D 40, and reassemble.
4. I'm all out of ideas.. If that didn't fix it, I'd go get a new one.
Best of luck, --W/D--
Aug 13, 2009 | Air Tools & Compressors
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
Milwaukee M18 Compact Drill & Impact Driver Combo Kit 2691-22 Logo
Top Milwaukee Tools & Hardware - Others Experts
Joseph Mueller
Joseph Mueller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Milwaukee Tool and Hardware - Other Expert? Answer questions, earn points and help others
