Question about CSi Speco Speco Rqs5c 4Camera Color Quad Splitter
HAD POWER OUTAGE AND CAMERA ONLY MAKING NOISE, NO SIGNAL ON SCREEN
Only have a blue screen & shows channel 3. This happened after a power outage.
Can you still access the menu functions? You can try to re search for cable channels, or antenna depending on what signal type you are using. That or the outage may have ruined your tv
Sep 02, 2014 | Quasar Televison & Video
VW Caddy radio making a crackling noise and nothing on screen?
did you check the other fuse there is one for battery power which will cause this it control radio memory and some other functions the other being the ignition controls just the power to the radio and not the mem
Jan 13, 2013 | Cars & Trucks
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Clicking noise after power outage
If you had a clicking noise about once a minute for 3 to 5 times, then unit worked fine, you have no problem, it was just letting the pressure equalize in the system before the compressor could restart. (this happens if you had a very short power outage).
If you are getting many clicks and compressor is not starting, you will have to replace the motherboard.
May 27, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
No composite input signal
`Hi,
If the monitor is making the noise , the monitor circuit baord has gone bad.
If you have purchased the monitor on a seprate order from dell it would be covered under 3 yr warranty. If the same has been bought with the Dell computer , it would hold the computer warranty. would request you call the manufacturer.
Before you call Dell , you can try the following things
1. Disconnect call cables from the back of the montior
2. Press the power button a couple of times in the front of the monitor to drain any resident charge
3. Reconnect the power cable
4. check if you see the monitor self test running and if the noise is still there with there
Thanks
Proton
Oct 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
No power
What is making the clicking noise? Is it the case speaker or the hard drive?
Do you use a surge protector?
Jan 04, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Panasonic TV
The power surge has caused a failure of an internal component. If it is making this noise it is possible the line output transistor has failed. I would advise calling a service repair centre & have someone there take alook at it. All being well this may be the only problem. Power surges can sometimes cause other faults.
Dec 10, 2007 | Panasonic CT-36D20 36" TV
CSi Speco Speco Rqs5c 4Camera Color Quad Splitter Logo
26 people viewed this question
Top CSi Speco Home Security Experts
Lawrence Oravetz
Are you a CSi Speco Home Security Expert? Answer questions, earn points and help others
