Question about Intel CS331 Webcam
How to change the CS331 output resolution?
The default resolution for the CS331 is 160x120 on initialization. There's no way in the driver's options to change the default res, or even it's working output res; it's all dependant on the software using the cam. In the post-Gates Microsoft world, the default res is used in their newest Messenger without a clear way to change it, resulting in the image looking like ****. Help?
I have need diver
Posted on Nov 04, 2009
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
How you change the pic size, when i taka picture, the i get is 160x120, is there a way to get a larger pic...
Cameras on cell phones are low resolution cameras, this means less memory is needed.
To get larger picture, higher resolution picture/images you need to use a digital camera.
Sep 21, 2010 | Motorola Mobility RAZR V3
Intel drivers cs331 windows vista
1st You download Webcam Driver. Intel Cam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 21, 2010 | Intel CS331 Webcam
Intel CS331 web cam not compatible with Windows 7
THAT SOLUTION DOES NOT WORK!
ANYONE HAVE ANOTHER SOLUTION?!
Apr 10, 2010 | Intel CS331 Webcam
Is there a driver avaliable for windows 7 for a Intel CS331 Camera
That's a link to drivers for Windows XP. The question was for Windows 7. I have the same problem.
Mar 28, 2010 | Intel CS331 Webcam
How do you zoom on the samsung smooth phone camera
The Samsung Smooth only lets you zoom if you choose one of the two lower resolutions (320x240 or 160x120). Once one of those resolutions has been chosen, then pushing the buttons to the right and left of the OK button allow you to zoom.
Sep 18, 2009 | Cell Phones
Resolution is low!
Easiest was is go to Camera Menu -> Initialize -> Yes.
Camera will reset and select factory default settings.
Other way is set camera on camera-mode, press menu and find picture resolution setup, you will see fine, standard, vga, email options there, select desired option and done.
Jan 18, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
1440x900 resolution required
check and make sure that you are using the Intel drivers and not the default windows xp drivers. The default drivers are very limited and only offer a few different resolutions to choose from.
Nov 20, 2007 | Intel D845GVSR Motherboard
Intel CS331 Webcam Logo
120 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
