Question about Linksys, A Division of Cisco Systems, Inc. Linksys WCG200 Wireless-G Cable Gateway
I am unable to delete my Wireless G notebook adapter in my add and remove programs [error 5001 Oxffffec75] pops up
I have a wireless G Linksys notebook adapter WPC54G ver.3.1 that is missing a Dll. file so Im trying to delete the program in my add or remove programs in the control panel and it gives me an error code [-5001 : 0xffffec75] and I am stumped because there is nothing left to delete any where in my computer.
How do I uninstall Linksys wusb300N adapter drivers without the software? The drivers are conflicting with my new N-PCI adapter. Linksys says I need to remove the drivers from my registry? Need help on...
Assuming you are using mirosoft windows, open the control, open "add or Remove Programs" select the linksys software, and click on remove. Then restart the computer.
Aug 18, 2010 | Linksys WUSB300N Wireless Adapter
I am using a Linksys Wireless-G 2.4 GHz wireless device and keep getting the error message: "Linksys Wireless-G USB Wireless Network MonitorWLAN.ini can't found" popping up every 20 seconds or so. The...
Its a system error(wlan.INI).Better you can download that file and save it in c:program files\linksys wireless(if any)
otherwise wireless related folder in C drive
Dec 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Cannot load ProcNICs.dll error
you can goto start button, run, then type, msconfig
then startup uncheck if its listed ... that will get rid of the error probly if that doesnt work goto control panel add remove programs and uninstall the linksys program and reinstall it from a cd or download the latest version will probly fix the error
Nov 05, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Error message
It seems that the adapter is not installed properly ..... uninstall the adapter from control panel >> Add & remove programs Reinstall the adapter again by using it on different port .....
thus says linksys...
May 08, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys Wireless-G USB Wireless Network Monitor\wlan.ini can't
Start -> Control Panel -> Classic View -> Add/Remove Programs
Find the entry for the Linksys device.
Click "remove".
When it finishes, shutdown/reboot.
Apr 09, 2009 | Gateway Computers & Internet
Can't uninstall drivers for Linksys WUSB54GSC Compact Wireless-G USB Adapter
You can go to Control Panle then Add/remove program double click on it then look for the Linksys software there then just remove it , that will remove the software on your computer and you need to restart teh computer to complete the uninstallation..
Hope that helps.........
Oct 05, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Internet not changing pages
It may be a browser problem. You can try to re-install the current browser you are using or try installing a different browser.
Aug 03, 2008 | Linksys WUSB300N Wireless Adapter
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
I installed linksys wireless notebook adapter driver on my laptop it sayes wsastartup not installed
If the laptop is XP please do this:
Go to Control Panel>add/remove programs. Look for the Linksys Wireless Notebook adapter, select it, click remove. Keep the notebook adapter connected to your laptop.
Insert the driver disc, do not run the set up.
Restart the laptop, drivers should be loaded automatically.
If drivers were not loaded, go to DEVICE MANAGER, click on NETWORK ADAPTERS, select the Linksys, right click the Linksys, click update drivers.
Start the wizard, select Install from a list of specific location.
You can do this if you have the setup disc or the downloaded drivers on your laptop.
If you are still having this problem you can call Linksys tech support 1800-3267114.
Good Day
Mar 15, 2008 | Computers & Internet
Linksys wireless g notbook adapter
From my experience with stubborn program removals, I go into regedit and search for all instances of the manufacturer name or related terms. Go to "Start", "run" and type "regedit" to enter the registry. Reboot system after changes are made. Have access to back-up easily available (how you do that is up to you). I delete those registery references. This has happened many times when I have uninstalled programs. That has typically corrected the problem. NOTE: please do this carefully, back-up the registry prior to monkeying with it. If you are not comfortable doing this then you are stuck or will need to take it to someone who knows.
Feb 10, 2007 | Linksys Wireless-G WRTP54G Router
Computers & Internet Logo
24 people viewed this question
Top Linksys, A Division of Cisco Systems, Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Linksys, A Division of Cisco Systems, Inc. Computer and Internet Expert? Answer questions, earn points and help others
