Question about Digital Audio Audio Players & Recorders
How do you wire up a ┬ĚDigital Research Da V Digital Home Theater Subwoofer And Satellites ..
night71
  • 328 Answers
SOURCE: dis-assembling subwoofer
Unless you are good with wiring and can accept having the front cover broken, then you can do it yourself. The speaker protector can be gently pried off but will probably break if not done perfectly. If you get the front cover off, there should be 4 screws holding the speaker. Remove them and then you can see inside. Take note of how the resisters are attached. You may need to solder if they are separated. If you are confident handling this job, go for it, if not, take it to your local repair shop.
Posted on Oct 29, 2007
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
SOURCE: I have a teac AG
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Posted on Apr 16, 2009
  • 151 Answers
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
My hkts 15 subwoofer sounds blown. Ive tested the speaker and its not. I sent it in for repair and they could not find anything. Now I thinking its the amp? One day it started working fine and then sounded...
It could be either bad parts or bad solder connections or both but I agree with you if did what you said. Amp will have to be run for a while to know if it or something else.
A scope monitoring the line with the issue will be able to see when it fails.
Dec 21, 2012 | Harmon Kardon HKTS 15 5.1 Home Theater...
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
I need to know the website or the retailer for this brand so I can contact them for the full set, all I have is the subwoofer. can anyone help me out?
You might want to read some user feedback before investing any more money into this product line. Any published 'specs' would be as suspect as their sonic pedigree.
http://forum.ecoustics.com/bbs/messages/3/245643.html
The concensus is it's a scam.
Some opinions...
"anyone who writes that these things sound fine is either making money off of them, a scam victim seeking to pawn off his folly on someone else, or they need to have a root canal performed on their ears."
"If you get approached by people trying to sell you this stuff, take some pictures of them , get a plate # , and call your local police and local news.
Do a search for white van speakers , you'll find some interesting reviews ..
Don't get Scammed ! Brands sold out of white speaker vans or suv
Audiofile
Acoustic Monitor
Acoustic Response,
Acoustic Image, Acoustic Lab Technology
Dan Wave
Denmark
Dogg Digital,
Digital Dogg Audio
Dahlton
Digital Research
DiVinci
Dynalab
Epiphany
Genesis Media Labs
Grafdale
Digital Pro Audio,
Pro Audio,
Digital Audio,
Digital Audio Professional Speaker Systems,
Digital Audio Skyline
Digital Research
Elite Audio
Epiphany Audio
KEV
Kirsch
Matrix Audio Concepts
Millennium Theater Systems (MTS)
Omni Audio
Palermo
Premier Acoustics
Protecsound
Pro Dynamics
Paradyme
PSD
PTS
TNA
Theater Research
Feb 02, 2011 | Elite Audio EA-6040 Theater System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
F61 is showin up on my system ,an it wouldn stay on
It is the digital amp IC damaged.
Need replacement.
Nov 14, 2008 | Panasonic Home Theater System System
505 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Terry Hair
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
