Question about GE GFWN1100LWW Laundry : Front Load Washers
Loud noise during spin cycle
It is level and makes no difference if the clothes are evenly distributed (balanced) or not. It is a screaming noise not a knocking noise.
5 Suggested Answers
COXY
  • 76 Answers
SOURCE: loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Posted on Oct 18, 2007
BADBOYJAY
  • 264 Answers
SOURCE: Loud Noise on Spin Cycle
it could be 1 of 3 thing if the banging is coming from the case then your suspension legs are no good you will need to right down your model number and go on ebay or to you local appliances shop they will help you or even take a look you will save a lot of time and money if you go and see your local second hand shop that do appliances they will do the job relay cheep £25-£30 pound with the legs
Posted on Jan 07, 2008
  • 464 Answers
SOURCE: my washer makes a real loud sound on the spin
check part #370 in this picture there are 4 of them, one at each corner, they are black heavy rubber bands to keep the tub centered. maybe that one or more are broken. if they are ok, then check the rod and spring assemblies, one at the front and one at the back. they are long and are part of the suspension system. hope this will help250 you.
Posted on Oct 24, 2009
SOURCE: machine making a knocking noise during spin cycle
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Posted on Nov 17, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
MY WASH MACHINE IS A 1YR OLD WHEN SPIN MAKE LOUD NOISE AND OFF BALANCE.
Your clothing inside the machine is not evenly spread out. So clothes packed too heavy on one side makes the machine off balance. Re-distribute the clothing so it is even in weight.
May 02, 2011 | Home
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Loud screaming sound during spin cycle
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE GFWN1100LWW Laundry : Front Load Washers Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
