Question about Mercedes-Benz 1996 Mercedes C-Class Sedan - Snow/Surfboard Carrier -
Mercedes c200 stuck in 1st gear - Mercedes-Benz 1996 Mercedes C-Class Sedan - Snow/Surfboard Carrier -
  • 3 Answers
SOURCE: Mercedes after shifting to reverse to drive the 1st gear slips
mercedes did nothing wrong your transmission is probably blown up. no way they could put in the wrong parts they wouldn't fit. how many miles are on your trans now? did you ever do a transmission service on the transmission that mercedes says is lifetime fluid? dont do back to the dealer find an independant shop that specializes in mercedes, like the one i work for. the dealer doesnt care about its clients. Us independants honestly do care
Posted on May 11, 2009
  • 5 Answers
SOURCE: 1994 Mercedes C200 Elegance Auto Box Fault
Check for the transmission setting ( around the shifter area "S and W"). Select switch to S. W is only used on wet or snow condition.
Posted on Jun 02, 2009
  • 24 Answers
SOURCE: MERCEDES NOT CHANGING GEARS
it should be in 2nd gear your gearbox is in limp mode need to have it looked at a.s.a.p ( the oil level may low)
Posted on Feb 21, 2010
  • 2428 Answers
SOURCE: I have a Mercedes benz, C200, 1996, Elegance. It vibtrates on reverse gear. All other gears are okay
If its a standard transmission its likely a bearing called the pilot bearing . Its a needle bearing that fits into the flywheel and the transmission shaft fits into it .If its worn the transmission will jump in reverse move up and down on the rubber mount . Or if its an automatic then its likely the rubber mount it self or a motor mount witch is also a rubber mount there is 2 on the motor and 1 on the trany
Posted on Apr 03, 2012
emissionwiz
  • 76080 Answers
SOURCE: where you put transmission oil in a kompressor c200 2003 model
The transmission is sealed and has no fill point, see the dealer for service and adding of fluid.
Posted on Jul 20, 2012
Merc c200
Normally you drivecaway in your second gear if it'scan auromatic gear unit, but bumpy is a vacuum tube which needs to becreplaced .
Aug 18, 2014 | Mercedes-Benz C-Class Cars & Trucks
I HAVE A S500 THAT GET STUCK IN 1ST GEAR SUM TIME BUT WHEN I CUT THE CAR OFF AN RESTART IT THE CAR SHIFTS FINE
check that the clutch is properly disengaging when you go to change gears . If there is any drag at all on the input shaft then 1st gear will try to stay engaged because of the load on the gear teeth.
Dec 23, 2013 | 2001 Mercedes-Benz S-Class
My Mercedes C200 Komp has started sticking in 2nd or 3rd gear for the first journey of the day only(?) Been advised of a gear box oil leak and told that an Electrol spped plate, filter, oil and plug is...
hi check and clean the MS air flow sensor, also the gear box needs a service every 2 years. now the service technician will tell you major gear box problems but it happened to me aswell and it turns out the valves inside the gear box was sticking to the valve body and causing the gears to stay in a specific gear till it reaches the rev limiter and would change. so after i got the oil and filter changed on my box, it still got stuck but dont worry as thats a common problem with a very easy solution, take the car on a long road and really put your foot down, let the engine and gear box temperature rise from hard driving and the valves should release itself from the body of the box and re-lubricate itself not to get stuck again
Feb 04, 2013 | 2004 Mercedes-Benz C-Class
Where you put transmission oil in a kompressor c200 2003 model
Jul 19, 2012 | 2004 Mercedes-Benz C-Class
Apr 03, 2012 | 1996 Mercedes-Benz C-Class
I have a mercedes c200 komprosser. wat is the use of s and w switch next to the gear shifter. And wat is the use of emc switch on the dash board. thanks. hope you will respond soon.
It has to do with the transmission. The 'S' stands for standard and 'W' winter.
In 'S' mode, the transmission starts out in 1st gear normally, but when you select
In 'W' mode, the transmission will start out in 2nd gear, to help reduce wheel spin/slip on slippery surfaces.
EMC (Emirates Motor Company) means that it was destined for the middle east suchas Saudi or Kuwait etc.... Check out the link below for more info.
http://www.ameinfo.com/175003.html
May 03, 2011 | Mercedes-Benz C230 Cars & Trucks
A few problems with a Merc W202 C200 1994 Auto
1st starting problem is properly faulty fuel pump 2nd its not the suspension its your shocker absorbers 3rd the air con has an air blockage
Sep 18, 2009 | 1994 Mercedes-Benz C-Class
Mercedes-Benz 1996 Mercedes C-Class Sedan - Snow/Surfboard Carrier - Logo
635 people viewed this question
Top Mercedes-Benz Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Mercedes-Benz Water Sport Expert? Answer questions, earn points and help others
